ad: AbAuRe-1
Yaesu Announces FT-25R and FT-65R Handheld Transceivers
Discussion in 'Amateur Radio News' started by W4LKO, Feb 7, 2017.
  1. KG5EXW
    KG5EXW Ham Member QRZ Page
    There's nothing on the Yaesu site. Are you a Gigapart shill?
  2. AD0MI
    AD0MI Ham Member QRZ Page
  3. AD5KO
    AD5KO Ham Member QRZ Page
    That's not even a transceiver it's a scanner, let alone a digital transceiver which is what N8JUC was talking about.
    For example, the FT-1XDR is a very good $300.00 portable which among other things does Yaesu digital. N8JUC was talking about a $150.oo digital portable and hoping this new Yaesu portable was it. Well actually a $169.95 radio.
    NL7W likes this.
  4. KC6SOT
    KC6SOT Ham Member QRZ Page
    Yaesu is going down the toilet. Look at Fusion. OMG. Too many problems. I'll stick with DMR. It works.
    KV4BL likes this.
  5. AD5KO
    The Alinco DJ-500 dual band portable. $99.99 from HRO and $99.00 at Gigaparts.
    I have owned this radio and it's well made and sounds good.
    So why the new goofy portables from Yaesu?
    KV4BL likes this.
  6. KA0HCP
    Unfortunately Yaesu has been blowing sunshine up amateurs behinds for years with similar statements.
    Mil-810 is a testing procedure guideline, not a certification. Its up to the military procuring agency to set the passing standards. Yaesu does not tell us anything about what tests were actually performed, number of units tested, the results and what they consider 'passing". ;)
    p.s. The current standard is Mil-810-G, issued in 2008. Yaesu is two revisions and 17 years behind in using outdated standard "E".
    KV4BL likes this.
  7. AD5KO
    This is an Alinco DJ-A10, it's a commercial portable I have used on the job. It performs very well and has great 1 watt audio, and the color of the display can be changed. Take a close look at it and compare it to the new Yaesu's. Look familiar? For sometime I have suspected that Yaesu has been sold to a Chinese company just like Alinco, but I hope I am wrong, although these new Alinco radios do perform very well. BTW, the flashlight is on the top and it does FM radio too, also notice the orange button...
  8. KG5EXW
  9. WD9EWK
    WD9EWK Ham Member QRZ Page
    If you go by the FCC certification, almost all amateur transceivers are certified as scanners, if they cover non-amateur spectrum above 30 MHz. The transmitters are not required to meet formal FCC certification, but do have to comply with the requirements listed in FCC Part 97. I remember seeing something on a web page that explained that the FT-70DR was going to be a dual-band HT with System Fusion. (and the D in the model number seems to be Yaesu's way to indicate "digital")
    For example, go to:
    http://www.fcc.gov/oet/ea/fccid/
    Enter K66 as the grantee code, and 20515X20 as the product code. This is for the FT-70DR mentioned previously. Or use the same K66 grantee code, and 20665X20 as the product code for the FT-65R. Both have certification grants that only describe these radios as receivers.
    73!
    AD5KO likes this.
  10. KQ7D
    KQ7D Ham Member QRZ Page
    Honest question:
    My simple Baofeng UV82HP is dual watch (two channels at once, either or both UHF/VHF). What other brand/model does this? Otherwise I love the FT-60.
    AD5KO likes this.
  11. AD5KO
    Ok, thanks Patrick... I am responding on my phone. 73.
  12. AD5KO
    I had a baofeng uv82. It was surprisingly good for $28.00 and not a bad design.
    Ft-60 great little radio.
    73.
    KQ7D likes this.
  13. WD9EWK
    Many radios, actually.
    Of the radios I have, two Wouxuns (KG-UV8D and KG-UV9D) and some Kenwoods (TH-D72A, TH-D74A, TH-F6A). It's actually a feature in a fair number of HTs, if they have two VFOs on the display. Granted, the Baofeng probably costs less than almost all of these, but this is something found in many other HTs and mobile radios.
    73!
  14. KQ7D
    $28 bucks? I hope my UV82-HP is somehow better because I paid something like $65! Regardless, it is pretty good for a Baofeng.
  15. AD5KO
    It was when they first came out and it was the 5watt version. :)
    KQ7D likes this.
