ad: w5yi
XIEGU G90 HEAD UNIT NOT POWER ON
Discussion in 'General Technical Questions and Answers' started by K2TLX, Aug 20, 2020.
  1. K2TLX
    K2TLX XML Subscriber QRZ Page
    Hello And Greetings My Fellow Hams
    1) Powered On My Xiegu G90 And Was Done Messing Around On 80 M With It
    2 ) Turned Off Radio Via My DC SWITCH
    3) Went To Turn On Radio Again To Get On 80 M Net To Talk And Head Unit No Lighting UP At All ANd Screen No Powering On Also I see It Pulling Current But No Power On Head Unit
    Did It Just Die?
    Thank You For Help
    OK1USU likes this.
    Are you using the head separated from the radio body?
  3. K2TLX
    No it stilll attached when i power it on i called xiegu and amayon there are doing a one for one swap with me
  4. VA3NKA
    VA3NKA XML Subscriber QRZ Page
    Same here. Just happened. I think it was the CAT cable that froze the radio and after reboot, the head unit did not light up.
  5. YU2MBX
    YU2MBX Ham Member QRZ Page
    I have the same problem with my new Xiegu G90. Can not power on. Mic get power light up for a second. Any suggestion how to fix this problem
  6. KC3PBI
    KC3PBI XML Subscriber QRZ Page
    Disconnect the cat serial cable- that's the lower 3.5mm connector on the left side of the head.
    If that serial interface receives anything when the radio is booting, it interprets that as "press any key for firmware utility" and does that instead of booting up into the normal radio interface.
    If you disconnect the serial cable OR put some good ferrite beads on that cat cable, you can eliminate the noise causing the radio to think you are trying to reload firmware in serial terminal mode.
    KL7KN likes this.
  7. VA3NKA
    I made it work by re-installing the firmware.
  8. W8DBC
    W8DBC XML Subscriber QRZ Page
    Thank you for posting this fix! I was able to just send the firmware for the display unit and it came back to life. You saved me a lot of trouble!
  9. F4HZT
    F4HZT Ham Member QRZ Page
    Hi,
    sorry for my bad english.
    Same with mine. I think it was the CAT cable that froze the radio and after reboot, the head unit did not light up too.
    Tried several techniques (F switch, PRE switch), and was able to send the firmware to the body and display unit, but the RTX remains the same.
    Display is blank (black), microphone lights up, little noise in the speaker. Nothing else.
  10. VA3NKA
    It happens sometimes to me too.
    Unplug the CAT cable, turn the radio off from power supply wait a bit and then turn it back on.
    Plug the CAT cable last.
    IF it does not work update the update the firmware, then plug out the CAT and reboot.
    the CAT is what freezes it.
    OH8STN likes this.
