ad: Schulman-1
WZ1M Transformer Rebuilds
Discussion in 'Amplitude Modulation' started by KA4KOE, Jun 15, 2017.
  1. KA4KOE
    KA4KOE Ham Member QRZ Page
    I emailed Gary WZ1M and forwarded the data to him about my mod iron in case it tests bad. The consensus is that the winding resistances are frequently not even (as The Don mentioned) and he even told me how to do a quick test, which I will perform shortly.
    The porpoise of this post is that Gary is a REALLY nice guy to deal with. He called me on his dime and we had a good chat. The cost to rebuild my mod iron was ball-parked but reasonable. Gary is 70 years old and shows no signs of slowing down. He is planning a move to Flori-DUH in the near future.
    Anyway, I just thought I'd pass this on.
    Fleep
    YF8RQN and AF6LJ like this.
  2. K4KYV
    Can you describe the quick test?
    AF6LJ likes this.
  3. KA4KOE
    Put about 50VAC (watch current and use a variac) across the primary. Measure the AC voltage across both sides of the mod secondary. If they differ by more than a couple of volts, there is a hi-z short somewhere.
    AF6LJ likes this.
  4. AF6LJ
    AF6LJ Ham Member QRZ Page
    You should also be able to "Ring" a transformer with a square wave on the input and look for asymmetry and distortion in the ringing on the windings.
    AC0OB likes this.
  5. W7TFO
    W7TFO Platinum Subscriber Platinum Subscriber QRZ Page
    Gary declined rebuilding a big (100lb) Thordarson for me.
    More DIY now I suppose.
    73DG
    AF6LJ likes this.
  6. WZ1M
    WZ1M Ham Member QRZ Page
    After the major heart attack, I was just taking it easy and no heavy stuff.
    Regards,
    TRS
    Gary
    N6YW, AF6LJ and (deleted member) like this.
  7. WZ1M
    A ring test is not always very good. Some transformers show good signs of ringing and others are hard to decifier if the pattern is good or bad. I shy away from this type of test as there are many other tests that will do just fine.
    Regards,
    TRS
    Gary
    KA2PTE and AF6LJ like this.
  8. AF6LJ
    This is good to know, thanks Gary.
  9. W7TFO
    I don't blame you, rest easy.
    73DG
    AF6LJ likes this.
  10. K5UJ
    K5UJ Ham Member QRZ Page
    The Eldico TR1 866A filament transformer buzzed like a door buzzer. Ken W0HRO suggested I bake it in my oven, 185 degrees for 4 hours. Worth a try. After an hour I ended the experiment because it was August and I had the A/C on since the oven heated up the house (if I ever run the oven it is only in winter normally) and after an hour the transformer stank up the place. That was when I learned iron baking is normally done outside.
    I could have bought some junk toaster oven at a garage sale, and a pint of transformer resin (a.k.a. shellac, or varnish) for $85, and dipped and baked it myself but for $25 shipping included, Gary removed the end bells and did all that and a 4 KV hi-pot test. That transformer makes zero noise now.
    AF6LJ likes this.
ad: KE5EXXad-1
