ad: M2Ant-1
WSJT-X not decoding
Discussion in 'Working Different Modes' started by W8WV, Sep 6, 2018.
  1. KG5THG
    KG5THG XML Subscriber QRZ Page
    Ok, for some reason I was thinking you were dealing with ft8. Your saying not decoding any wsjt-x transmissions regardless of the mode. Sorry about my confusion. What software did you download for the using network time?
  2. KG5THG
    Just an fyi while we're thinking on this. If you set the waterfall to bins/pixel to 6 it may be easier to read the signals.
  3. KG5THG
    I use Meinberg for NTP (https://www.meinbergglobal.com/english/sw/ntp.htm) and sometimes it can fail to start or Microsoft knocks it down. If you use Meinberg, under apps for Meinberg, what does it say when you run "quick ntp status". If you don't use Meinberg, what does the equivalent for your software say?
  4. K3DCW
    Go to the WSJT-X settings and make sure you do NOT have a check mark next to "Monitor off at startup."
  5. W8WV
    W8WV XML Subscriber QRZ Page
  6. W8WV
  7. W8WV
    It is uncheck - assume I would not see green Monitor light on screen
  8. K3DCW
    Looking at your screenshot, you have JT9 selected as your mode, but you are on the JT65 frequency. Neither JT9 or JT65 are much in use any longer, since the arrival of FT8. Tune your rig to 14074kHz and go to the WJST-X MODE menu and put it into FT8 mode and you should see decodes within 15 seconds or so.
  9. W8WV
  10. W8WV
    Changed Freq and mode - still no decode
