WSJT-X not decoding
Discussion in 'Working Different Modes' started by W8WV, Sep 6, 2018.
  1. ND6M
    ND6M Ham Member QRZ Page
    Well, seeing as nothing else has fixed it.
    completely delete the program, re-download it and install
  2. KG5THG
    KG5THG XML Subscriber QRZ Page
  3. K3XR
    K3XR Ham Member QRZ Page
    Never used HRD so don't know if it has it's own "built in" version of WSJT-X or if you are using the download from the K1JT site in which case you might want to try the stand alone program minus the HRD and see how that works out.
  4. KD3WB
    KD3WB Ham Member QRZ Page
    If you are using a laptop, make sure its internal microphone is disabled or turned all the way down. Also, make sure you are listening to a part of the band where FT8 can be expected to be heard. Lots of signals on 14.074 here in Maryland at the moment.
    Ben
  5. KD3WB
    Also make sure that the mode on WSJT-X is set to FT8.
    Ben
    K3XR likes this.
  6. W8WV
    W8WV XML Subscriber QRZ Page
  7. W8WV
    I have done all the suggestion...…..nothing changes
  8. KG5THG
    Can you post a screen shot of your wsjt-x window and the water fall window?
  9. W8WV
  10. W8WV
