WSJT-X not decoding
Discussion in 'Working Different Modes' started by W8WV, Sep 6, 2018.
  1. W8WV
    W8WV XML Subscriber QRZ Page
    WSJT-X ver 1.9.1
    Rig - Yaesu FTDX-1200 with SCU-17
    HamRadio Deluxe
    Under the radio tab in WSJT-X I can test CAT and PTT and all seems well.
    I can see the waterfall and can send a CQ, but it isn't decoding.
    What am I do wrong?
    Any ideas?
    Thanks
    Bob W8WV
  2. ND6M
    ND6M Ham Member QRZ Page
    check your computer clock time.
    turn DOWN the sound card input level.;)
    M7PRL likes this.
  3. KD3WB
    KD3WB Ham Member QRZ Page
  4. W8WV
    I have NETWORK TIME install and synced.....and the RX to 30db. Still no decode
  5. KD3WB
    If you are using Windows 10, press the Windows and "i" keys simultaneously, select "Privacy", "Microphone" and make sure that "Allow apps to access your microphone" is on.
    Ben
    KA0HCP likes this.
  6. W8WV
    Microphone access is ON
  7. K3XR
    K3XR Ham Member QRZ Page
    Most of the problems encountered with digital modes find to have been...
    Accurate time use a program like Dimension 4 (V5.31)
    I prefer to use one of the USB GPS receivers looks like a small hockey puck reasonable new or used on Ebay along with the program GPStime. There are other programs and methods.
    Sound Card selection and adjustment can be often be the culprit .
    In some cases simply restart the computer and everything seems to get into sync.
    Stay with it have had the same frustration a number of times.
  8. W8WV
    Thanks.....I still don't have this darn thing decoding:(
  9. KA0HCP
    After a Win10 Update in early June, my USB Audio was disabled and Neither FT8 nor FlDigi can receives audio now. I have been working for two months troubleshooting. Extremely frustrating as this has cutoff my main operating modes. Arghh.
  10. KD3WB
    Start WSJT-X, click "File", "Settings", click on the "Audio" tab and make sure that the input is set correctly. If it isn't, change it and click "OK".
    Ben
    KG5THG, KA0HCP and K3XR like this.
