WSJT-X Full-Auto mod
Discussion in 'Working Different Modes' started by SQ9FVE, Mar 27, 2019.
  1. EA4BPN
    EA4BPN Ham Member QRZ Page
    Yes, it is logged properly on the .adi file.
    Unfortunately lost the source code and patch for 2.0.1 so I can not compare it if there is any significative difference.
  2. SQ9FVE
    SQ9FVE Ham Member QRZ Page
    What have you checked on the Filtering tab?
    That was just now, looks ok.
  3. EA4BPN
    I see. As I told you before, that is not happen here...
    I did not take a picture, so cannot show you... But, it was 'New on band' and 'New grid on band'. Also filtered signal to -15dB.
    I will try again and collect all the info for good debuging, :cool:
  4. SQ9FVE
    Awesome, thanks!
  5. EA4BPN
    Well, it happens with dupe contact. See:
    Look the .adi file for DF4UE worked 20190426 and now the program call him again (auto call is disable because it was replying)
  6. SQ9FVE
    Can you post your Filters tab too?
  7. EA4BPN
    Ok. Here they are:
    Tab 4 also:
    Captura de pantalla_2019-05-14_20-45-07.jpg :
    Hope this helps.
  8. EA4BPN
    Forgot to mention and it could be important. I use ADIFMaster to modify the .adi file when is required:
    Rafael
  9. SQ9FVE
    Ok, that may be the issue. Please tick the New Call and New Call on Band under Colors, so that next time it happens you will be able to see if wsjtx treats this station as new. My filters basically use the built in wsjtx logic to do that.
  10. VA3SF
    VA3SF Premium Subscriber QRZ Page
    Test message
