ad: M2Ant-1
WSJT-X DXpedition Mode Question
Discussion in 'Amateur Radio Software' started by WL7CG, Aug 17, 2018.
  1. WL7CG
    WL7CG Premium Subscriber QRZ Page
    A couple islands are supposed to be on using this mode, so I thought I would try it.
    I have run into a problem with it that I can't resolve. On 14.090, the SWR is high with my FT-950 in the hound mode. If I key the mike at 14.090, the SWL is normal. If I go down to 14.080, it is normal. If I use JTDX on 14.090, the SWR is normal.
    I can't figure out what would be different using WSJT-X in hound mode at 14.090. The internal tuner on the radio is working, so the SWR isn't way out of range.
    If anyone has a suggestion, please let me know.
  2. OZ1ANJ
    OZ1ANJ Ham Member QRZ Page
    Your B VFO is on an other band
  3. WL7CG
    Thanks - That was an initial thought.
  4. OZ1ANJ
    Then i have no idea, i also have a FT-950, never had that problem.
    Good luck solving it.
  5. OZ1ANJ
    BTW, i use "Fake it" split mode, have you tried that?
