WSJT-X and setting Windows 10 clock seconds
Discussion in 'Working Different Modes' started by W4LKR, Dec 18, 2017.
  1. W4LKR
    W4LKR Ham Member QRZ Page
    The WSJT-X user guide says my PC clock must be within 1 second of UTC. I can set the time in Windows 10 to the minute, but strangely there isn't an input for seconds. No matter what I do, the new time I set doesn't ever reset to 00 seconds.
    How are you guys syncing Windows 10 time to the second?
  2. KD2NOM
    KD2NOM XML Subscriber QRZ Page
  3. VA3VF
    VA3VF Guest
    N1NA, KP4SX, K7JEM and 1 other person like this.
  4. KJ3N
    KJ3N Ham Member QRZ Page
  5. K3XR
    K3XR Ham Member QRZ Page
    Do search for a USB GPS receiver here is one on Ebay at the moment used under $20.00 use one in the shack and also camping as it does not need an internet connection there are a few free programs available just search for GPS time.
    Globalsat BU353 SiRF Star 4 USB GPS Receiver Navigation for PC
  6. N9RMA
    N9RMA Ham Member QRZ Page
    If you download any NTP sites; be sure and disable the internal windows clock... I have win 10 and it is not accurate enough for digi modes... They kept bumping noses and nothing was working right.. Now all is OK... Bob N9RMA
  7. VA3VF
    VA3VF Guest
    And if $20 is too much, there is an alternative at $8. It's based on the u-Blox chip, and works with BktTimeSync, which is another NTP software, but also supports GPS.
    http://www.maniaradio.it/en/bkttimesync.html
    If no GPS, use Dimension 4 only. If GPS is also used, while away from the internet for example, use BktTimeSync for both.
  8. VA3VF
    VA3VF Guest
    Very good point!
    K3XR likes this.
  9. W4LKR
    Thanks for the quick answers. I'm going to try one of the SNTP options first.
    With programs like Dimension 4 and NetTime, is UTC the default or must I select UTC from a list of options after it's installed and running?
  10. W4LKR
    Pardon my ignorance, I'm a little confused on this point. As I read about NetTime, I got the impression that it kept the internal clock in-syn with the time server. In other words, it sounded like the internal clock is still running and is in fact what gets referenced by WSJT-X and my logging program. If I disable it, how does the synced time from NetTime become visible to WSJT-X?
