Wouxun KG-UV9D - not full-duplex on SO-50, but getting better
Discussion in 'Satellite and Space Communications' started by WD9EWK, Aug 2, 2015.
  1. WD9EWK
    WD9EWK Ham Member QRZ Page
    Hopefully that smaller tuning step is in the firmware of the model you receive.
    I don't know how quickly the CHIRP group will get around to adding full support for these Wouxun radios. It seems like support comes faster if they receive a radio that can be used in their testing. I haven't seen a separate Wouxun software package for the KG-UV9D Plus, but one may exist somewhere.
    73!
  2. PA2EM
    PA2EM Ham Member QRZ Page
    Alle wouxun software& manuals including 8D, 8D plus, 9D, 9Dplus are on: www.wouxun.com/resource.aspx
    For the new menu functions see: KG-UV9D(Plus) Folding Instruction
    I have an FTDI programming cable ( http://www.miklor.com/COM/UV_GettingStarted.php ) which might do the job
    The (used) Elk antenna arrived yesterday; I will try to replace the PL-259 connector with N or SMA
    The Wouxun 9D+was shipped three days ago from China... usually it requires 6 weeks to arrive.
    73, have fun
    WD9EWK likes this.
  3. K6LCS
    K6LCS Premium Subscriber QRZ Page
  4. WD9EWK
    Thanks for pointing that out. I had not looked at that page in a while. Nice to see Wouxun put up the files for the UV9D Plus.
    That programming cable should be fine. I have one of those for my Wouxun and Baofeng radios, and it works with CHIRP and the Wouxun software for my UV8D and UV9D. The Elk is a great antenna for satellite work. When you get the radio and start working with it, please come back here and report on that radio. Especially if you work AO-85 (or SO-50) with it.
    73!
  5. WD9EWK
    I read that, but you didn't read and comprehend what I wrote. Note the highlighted portion above in your quote. I didn't say something like "I haven't seen a separate Wouxun or third-party software packages ... " or "I haven't seen any software packages ... " in my earlier post. I hadn't visited the Wouxun download page in a while, but after seeing PA2EM's message I went there and saw the files as he mentioned. With the Wouxun programming software and a suitable programming cable, that saves having to spend $50 for the software/cable combination you mentioned.
    If you mention RT Systems one more time in this thread, will you get a set of steak knives? :)
    KO4MA and W5PFG like this.
  6. W5PFG
    W5PFG Premium Subscriber QRZ Page
    Super Bass-o-matic perhaps?
    WD9EWK likes this.
  7. WD9EWK
    The original '76 version I remember seeing on TV a long time ago, or something newer?
  8. W5PFG
    I believe the term these days is "vintage." :)
  9. PA2EM
    The KG-UV9D plus already arrived yesterday! And yes it has 2.5Khz step.
    In the last two weeks my old KG-UVD1P did receive AO85 using the Elk antenna.
    I was not yet able to get through using simplex transmit with the many stations here.
    The KG-UVD1P was programmed in this way:
    SO50-on 436.815.000 split 145.850.000 Tone 74.4
    SO50-1 436.815.000 split 145.850.000 Tone 67.0
    SO50-2 436.810.000 split 145.850.000 Tone 67.0
    SO50-3 436.805.000 split 145.850.000 Tone 67.0
    SO50-4 436.800.000 split 145.850.000 Tone 67.0
    SO50-5 436.795.000 split 145.850.000 Tone 67.0
    SO50-6 436.790.000 split 145.850.000 Tone 67.0
    SO50-7 436.785.000 split 145.850.000 Tone 67.0
    AO85-1 145.980.000 split 435.160.000 Tone 67.0
    AO85-2 145.980.000 split 435.165.000 Tone 67.0
    AO85-3 145.980.000 split 435.170.000 Tone 67.0
    AO85-4 145.975.000 split 435.175.000 Tone 67.0
    AO85-5 145.975.000 split 435.180.000 Tone 67.0
    ISS-Packet Smplx 145.825.000
    ISS-Voice & SSTV 145.800.000 split 145.200.000 (this is for region 1 EU)
    (so far only tried AO85)
    What is a good programming table for the KG-UV9D using the 2.5Khz step?
  10. PA2EM
    No (E) indication on the box or on the front. 2.5 khz works and so far it keeps on displaying english text
    IMG_4651.JPG ]
ad: M2Ant-1
