wouxun KG-UV8D [PLUS]
Discussion in 'Amateur Radio Software' started by SV1SGA, Sep 18, 2017.
  1. SV1SGA
    SV1SGA Ham Member QRZ Page
    hello. does anyone know how to LIMIT THE FREQUENCY in WOUXUN KG-UV8D PLUS? do you know if there is a programme to do this, cause i tried to do it with the original progamme which i've downloaded from the site of wouxoun and it's impossible. thanks!!
  2. K5URU
    K5URU Ham Member QRZ Page
    The program you are looking for is called KG-UV8D Frequency Limit. Here is a Miklor page that has a download link and instructions near the bottom of the page. The download link is labeled "KG-UV8D Freq Limit B2.XPV140118 setup.exe" and the instructions are labeled "Running the program". Hopefully, this will work with the PLUS version of the KG-UV8D.
    http://www.miklor.com/UV8D/UV8D-Software.php
    Good luck and enjoy the radio!
    -Blake K5URU
  3. SV1SGA
    thank you for the quick response. i have tried this but it does not work.
    does anyone know in general if the plus model accepts limit frequency?
  4. ZONK666
    ZONK666 QRZ Member
    The same here....
    Searching for a software to mod the frequency range in Wouxun KG-UV8D PLUS to limit the frequency in due to the local rules.
    best regards, 73 de
  5. ZONK666
    ZONK666 QRZ Member
    Frequency mod done, CHIRP did the job.
  6. N1ART
    N1ART Ham Member QRZ Page
    Yes Chirp works no problem,you can use CHIRP to expand it to do 220-225 transmit and receive also, do not use on high power only low.
  7. KB2YLZ
    KB2YLZ Ham Member QRZ Page
    I cant seem to find an option to limit or extend frequency range on the current JUNE 2018 CHIRP for the UV8D PLUS. Can you advise where the option is or advise what date CHIRP release has the option.
    Thank You
ad: hrd-2
