WinEQF 3.1
Discussion in 'Logbooks & Logging Programs' started by N6BBS, Jan 30, 2016.
  1. RU6YY
    RU6YY Ham Member QRZ Page
    Import is possible from several formats, in particular ADIF. He is the most popular.
    The author LA6VJA has released a new version Win-EQF 3.08, which supports export to ADIF FT4 mode. Thanks Torkel.
    See http://www.bitwrap.no/eqf/
  2. W3ON
    W3ON XML Subscriber QRZ Page
    Here is my copy of the Icom IC7610 RIG file for Win-Eqf.
    Icom IC-7610 ! Radio Model Number for display within Win-EQF*
    0.0 ! Update rate in seconds - 0 is fast, while 10 is slow!
    ! Acknowledge command, if required (leave blank if not)
    6 ! Bytes to receive from radio as ECHO or OK block
    ! Pacing or Initialize command, if required
    H ! Hexadecimal (H) or String (S) instruction data type
    F ! Commands sent to radio Forward (F) or Reverse (R) order
    ! -------------- FREQUENCY READ -------------------------
    FEFE98E003FD ! Command to receive operating FREQUENCY from radio
    11 ! Number of bytes expected from radio after FREQ command
    6 ! Starting byte position for FREQUENCY value
    5 ! Number of bytes in FREQUENCY value
    R ! Frequency decoded in Forward (F) or Reverse (R) order
    B ! BCD (B) or Weighted Binary (W)
    ! -------------- MODE READ ------------------------------
    FEFE98E004FD ! Command to receive operating MODE from radio
    7 ! Number bytes expected from radio after MODE command
    6 ! Starting byte position for MODE value
    1 ! Number of bytes in MODE value
    ! Bit mask for MODE value, if required
    3 ! Value for CW 7=CW-R, 3=CW
    0 ! Value for LSB
    1 ! Value for USB
    5 ! Value for FM
    2 ! Value for AM
    8,4,12,7 ! ! Value for FSK,RTTY,PKT,CWR
    ! -------------- FREQUENCY SET --------------------------
    FEFE98E0050000000000FD ! Command to set the operating FREQUENCY
    ! -------------- MODE SET -------------------------------
    FEFE98E00600FD ! Command to set the operating MODE
    0 ! Value for LSB
    1 ! Value for USB
    5 ! Value for FM
    2 ! Value for AM
    8,4,4,7,12 ! Value for FSK,RTTY,PKT,CWR,PSK
    ! --------------- FILTER SET for CW ---------------------
    FEFE98E01A0309FD ! 1A030 = 50 Hz. 1A0340 = 3600 Hz. 1A0331 = 2700 Hz. 1A0309FD = 500 Hz.
    ! -------------- FILTER SET for PHONE -------------------
    FEFE98E01A0328FD ! 1A030 = 50 Hz. 1A0340 = 3600 Hz. 1A0331 = 2700 Hz. 1A0328FD = 2400 Hz.
  3. W8RLS
    W8RLS Premium Subscriber QRZ Page
    I have WINEQF 3.09. I am a long time user. With the new windows 10 V2004, the import function no longer functions #2 to append the files at the end. Log book refreshes with no updates to the logbook. Please help.W8RLS Ron
  4. HA5LV
    HA5LV Ham Member QRZ Page
    I'm using W10 pro and the import-export function of Win-EQF v3.09 working flawlessly.
    73 Viktor HA5LV
  5. NU4N
    NU4N XML Subscriber QRZ Page
    Hello Viktor. I downloaded WIN-Eqf 3.09 and loaded with problem.
    I tried to take a file from my N3FJP ACLOG adif. file but cant seem to get it to load in the logbook even tho my adif file was converted.
    Any thoughts or help would be appreciated
    NU4n Dave 73's & Thanks
    e-mail dwtucker19@comcast.net
