windows lost the silicon drivers????
Discussion in 'Computers, Hardware, and Operating Systems' started by KE9RJM, Jun 24, 2018.
  1. KE9RJM
    KE9RJM Ham Member QRZ Page
    I had my ic-7300 all set up for wsjt-x, working fine a couple of hours ago. Just turned it back on and the Silicon driver that I had downloaded and installed is no longer in device manager so i don't have the codec option in audio.
    I tried to reinstall the driver but no luck...any ideas?
    Thanks, Bob
    KE9RJM
  2. W1XWX
    W1XWX XML Subscriber QRZ Page
    Turn on the radio with USB cable plugged in
    Go to Device Manger
    Look down the list for PORTS
    Right click any ports and select Properties
    Open Ports in the list and select Let me pick the driver manually
    Select the Silicon driver if it is listed
    Let us know if this works
  3. KA9JLM
    If it is Windows 10, You have to give the device permission. Did You do that ?
  4. KE9RJM
    The silicon port was greyed out and said i needed to connect the device...that led me to realize i had plugged the USB cable into a hub rather than the computer so i moved the cable and everything came back to life...many thanks for pointing me in the right direction.
    W1XWX likes this.
  5. W1XWX
    You are welcome.
  6. WA9SVD
    WA9SVD Ham Member QRZ Page
    I've always said, USB is "punt and PRAY."
