I cannot get my new Yaesu FTM-100dr/de to communicate with my laptop running Windows 10. I’m using the supplied Yaesu program of ADMS 9. All I get is an error on my radio. And the program says Format error or timeout. The program won’t even read my SD card info I have backed up. I went and tried to buy RT systems, but they are sold out.
Did you install the SCU-20 driver ? What is the radios Main Firmware Version ? There are 2 different versions of ADMS-9, You need to use the one that matches your Firmware version. Good Luck.
T Thank you. I’ll take a look. I have installed the driver. But I did not know on the two different versions of the program
Make sure the driver you are using is made for Win 10. The old driver only works on Win 8 or under. 10 is not supported using the old Unsigned driver. Good Luck. Just a minor bump it the road. You can make things work.
having the thing going on here updated my ftm-100dr looking for some help radio getting error mgs. n3jpp john
