Win10 PC: How to toggle an accessable hardware logic pin?
Discussion in 'Computers, Hardware, and Operating Systems' started by WA7ARK, Feb 25, 2020.
  1. WA7ARK
    WA7ARK Ham Member QRZ Page
    I have an requirement for a software/hardware solution for what I knew how to do years ago, using Basic and a parallel port...
    From a Windows10 computer, I would like some code that runs concurrently with other applications to generate a logic signal, synchronized with the computer's real time clock, that toggles a bit in some accessible hardware connector (real serial port, USB serial port, Arduino plugged into a USB?).
    For example, I might want a logic bit to go high within a few ms of when the computer's RTC reaches an even minute, and to go back low when the RTC rolls to an odd minute. A timing resolution of even a few 10s of ms is good enough.
    Under DOS, I knew how to do this using basic and a parallel port. Under windowsXP, I knew how to do this using VisualBasic, but how do I do something like this today?
    Any body help me?
  2. W9WQA
    W9WQA Ham Member QRZ Page
    wish we could, i had great fun doing assm in ;debug"
    ms gives free ? basic but its not ez like gw was. dont know if it does ports.
    its like ?small basic, cant remember...
    try ms basic
  3. KA9JLM
    K0UO likes this.
  4. W7UUU
  5. WA7ARK
    I read through the documentation, but do not see how to get it to control a hardware port pin. It makes no mention of hardware serial COM ports.
    Three physical actions that I might be able to detect that autoit can initiate are:
    Open/Close a CD tray (quite primitive)
    Play a sound file. ( guess I could send tones out the audio jack and decode them).
    Beep (easier)
  6. KA9JLM
    You normally use the system .DLL files to call the I/O functions that you want.
    Here is a website that explains the functions in the Windows 10 DLL system files.
    http://windows10dll.nirsoft.net/
    It is a Can Do, With a little homework. :)
  7. W5UAA
    W5UAA Ham Member QRZ Page
    Looks to me like the best way to accomplish this is through the Win32 API.
    https://docs.microsoft.com/en-us/windows/win32/sysinfo/time-functions
    https://www.xanthium.in/Controlling-DTR-and-RTS-pins-of-SerialPort-using-Win32-API
    But it'll take some effort. You may have to do some date/time conversion. And there might be some permission issues you have to work your way through to get directly to one of the RS-232 pins. Microsoft doesn't like it when people try to access the hardware directly anymore.
    KA9JLM likes this.
  8. N3DT
    N3DT Ham Member QRZ Page
    I use a 2N2222, 10K resistor and a couple 1N914's to key the DTR for FT8 from a usb to DB9 com port adapter with WSJT-X so it is doable. But don't ask me how in the software.
  9. KA9JLM
    Exactly.
    That is what AutoIt lets you do using DLL calls, To directly control system I/O.
    And the code that you make is blessed by the Windows OS.
  10. K7MEM
    K7MEM Ham Member QRZ Page
    Another possible option would be to access external ports from Cygwin. Then you can write C or C++ or something else. I use Cygwin regularly to run a antenna simulator written in C and run the Veriwell Verilog Simuator. And it all runs within a Windows 10 machine.
