Why do some folks like to be out of band?
Discussion in 'On-Air Operations - Q&A' started by W5NNX, Mar 13, 2020.
  1. W5NNX
    W5NNX QRZ Member QRZ Page
    Sitting here listeing to a KE( on 7299.5 and can hear him up well over 7.300. Why do some folks do that....
  2. K7JEM
    K7JEM Ham Member QRZ Page
    If he's on 7299.5 LSB, he is likely in band, if his radio is working well.
    AC1HH likes this.
  3. VK3YE
    VK3YE Ham Member QRZ Page
    If your dial is on 7301 LSB you'll still hear bits of an amateur signal even if it's legitimately all below 7300.
    Set dial to 7300 USB and see if you hear anything. If so then there might be an issue (unless it's your receiver's filtering).
    KV6O, N0TZU, K0UO and 1 other person like this.
  4. W5NNX
    Unfortunately, with a 1.5 wide signal he is definitely out of band. and myself and another distant station would hear him well above 300. He should have set for 7297
    K6LPM and ND6M like this.
  5. K7JEM
    How were you measuring his bandwidth? Most people have no clue how to properly do this. Was he on LSB?
    K0UO likes this.
  6. W5NNX
    LSB on 40 meters...that is typically what folks run on 40 Mtrs....SDR scope and separate receive antenna and receiver also
  7. W5UAA
    W5UAA Ham Member QRZ Page
    Only two possible answers:
    1) Ignorance
    2) He's one of those people who thinks the rules don't apply to him.
    K0UO likes this.
  8. K8JD
    K8JD Ham Member QRZ Page
    There are those who memorized the answers for the exam and forget them a week after they get on the air. All those frequency numbers are tough to recall.
    When I was a novice I had the band plan sheet taped to my wall. Lucky we were stuck to the Xtals freqs we had :D
    K0UO likes this.
  9. K0UO
    On SSB Most people stay 3Khz away from the band edge judt to be safe
    KD6AYP, K6LPM and N4UP like this.
  10. KA9JLM
    That is the correct way if you are on USB.
