Which Transformer for homebrew GS-31B
Discussion in 'Amateur Radio Amplifiers' started by K5JCT, Dec 25, 2011.
ad: OK1UUad-1
  1. IC8FAX
    IC8FAX Ham Member QRZ Page
    Hi,
    I would like to build a linear HF with the GS-31b.
    I have a transformer AT with the following characteristics:
    2400 VAC 0.90A.
    Can I use this transformer ?
    thanks
    Jack
  2. K9STH
    FAX:
    It should work fine.
    After rectification the 2400 volts will be higher and 900 mA is more than enough for 2000 watts input. The maximum ratings of the GS-31b are 1.4 amps cathode current at 3000 volts average with a maximum anode voltage of 6000 volts.
    http://www.nd2x.net/gs31b.html
    I have a transformer with a rating of 3200 volts at 1.2 amps that I am going to use with a pair of GS-31b tubes. That should let the tubes basically "loaf" at 1500 watts output.
  3. K5JCT
    K5JCT Ham Member QRZ Page
    We'll after much thought I have decided to sell the GS-31B and go with a pair of 3x5s. I have done extensive modifications to the Warrior chassis and still did not have room for the cooling system that the Russian tube requires. I want the amp to run much quieter that any cooling system big enough for the GS-31B.
    I want to show off the chassis work, but I left my camera at work today. Over 100 6-32 screws so far.
    PS Silver plated GS-31B $115 shipped to CONUS.
    Jimmy, K5JCT
  4. K9FV
    K9FV Ham Member QRZ Page
    What do you mean - "Over 100 6-32 screws so far"?
    If I didn't already have a spare GS31b I'd talk with you, that silver would look nice. Not sure how much less cooling the 2 of the 3-500Z tubes take, seems like my AL-82 amp is about as noisy as the 6 meter amp - they sit close together.... Both blow a good bit of air and sorta on noisy side.
    I do like the instant on for the 3-500Z tubes - that is NICE. Have you got your 5 vac filament transformer yet? 30 amps is it for a pair?
    73 de Ken H>
  5. K5JCT
    Ken
    I had to lower the back section of the chassis to fit the transformer and make some room for taller tubes. I made the mount for the fan, etc. It took a lot of screws to bolt it all together. Inside there will be almost nothing original. Almost all of the outside appearance will be stock.
    I haven't bought my filament transformer. It will likely come from RF parts or Ameritron.
    The final reason that pushed me over the edge on the side of the 3-500s is the glow. I would miss that. We'll the glow and the sleepless nights I had thinking about putting a cold war Russian tube in my 1963 American amp...I'm not one of those people that only buys American, etc. It just didn't seem right for the amp. I really wanted to see what it would do. I even made a mounting plate and filament/cathode rings. I was going to build up the amp with the GS-31 and work all the bugs out with it, then convert over to the 3-500s. However, after all of the chassis work I have done, I did not want to put the extra holes it that the different tube would require. It's a cool tube. I love the rugged looks of it. It was a hard decision.
  6. K5JCT
    Oops double posted the last one.
  7. K9FV
    Oh Jim, I fully understand the desire for the 3-500Z tubes. I had to think about it myself and gave in to the lower cost.... I think a lot of it was the "not sure I can even build a working amp" concerns and was trying to get it to work as cheap as possible. Wound up spending some extra money because of trying to "cheap out".
    I agree totally, if the final plan is for 3-500Z, I would NOT build first with the GS-31 tube. The Chassis work can be almost more work than the actual RF deck itself. Keep us posted with info and photos.
    73 de Ken H>
  8. IC8FAX
    K9STH
    Ok Glen
    thanks for replay.
    Jacob
