Where is the ground connection to the power supply chassis?
Discussion in 'Radio Circuits, Repair & Performance' started by N1QWI, Nov 9, 2020.
  1. N1QWI
    N1QWI Ham Member QRZ Page
  2. K7JEM
    K7JEM Ham Member QRZ Page
    N1QWI likes this.
  3. KL7AJ
    KL7AJ Ham Member QRZ Page
    Why would you expect a generic power supply to have an RF groind?
    KA9JLM likes this.
  4. AJ4GQ
    AJ4GQ XML Subscriber QRZ Page
  5. W9WQA
    W9WQA Ham Member QRZ Page
    this aint over, magic word
    AJ4GQ likes this.
  6. N1QWI
    Fair enough..I think I should have rewritten my question as: "Is it necessary to connect the ground screw in the back of the power supply to my station RF ground bus which goes to the third prong of the outlet"...Since it's connected anyway, via the power cord, isn't this redundant?
  7. AJ4GQ
    Here you go:
    N1QWI likes this.
  8. AJ4GQ
    My compliments Sir!
  9. KA9JLM
    HOT/-/COLD on a switching supply.
    Normally the printer is grounded using the AC cord. And that supply mounts to the 3D printer frame. (If used as intended.)
  10. N0TZU
    Yes it would be redundant for safety purposes. It could be dangerous unless your station ground is properly bonded to the AC power service ground rod, and the antenna coax grounded where it enters the house. Most likely it would not be useful for RF purposes unless you have some specific problem that is insolvable otherwise.
