What is going on with QRZ??? HELP
Discussion in 'Community Help Center' started by G0LZX, Oct 7, 2010.
  1. G0LZX
    G0LZX Ham Member QRZ Page
    i have been trying to edit my page on qrz.com and it just keeps reverting to the original state, no external links or pics???
    i've tried editing out the /ed/ parts of the html code but they just keep getting re inserted???
    it took me ages to get my page up and running and at the moment it looks really awful :-(
    and now i find i cant even access it to edit it as it says i've been loking up too many calls??? ffs i'm only trying to MANAGE my OWN PAGE !!
    can ANYONE PLEASE HELP, its driving me mad
    ricky G0LZX,
    ps my G1VWL page has the same code and is working fine
  2. W2TMN
    W2TMN DX Helper QRZ Page
    Hello G0LZX,
    I've tried removing the "/ed/" HTML tags you describe as being an issue. It appears that I have the same trouble as you when trying to edit the page. I'll inform an administrator of the possible issue. Please be patient.
    Tom
    W2TMN
  3. UA6JD
    UA6JD Moderator Volunteer DX Helper Platinum Subscriber QRZ Page
    Hi Ricky-
    I was send to you by e-mail with detail instruction how is fix your problem and new HTML code for insert. I am test it in my page and it work perfect.
    To everybody who have same problem below was instruction how is fix your problem for less then 5 minutes.
    If you never work with HTML code in HTML window please download my first book and read page 19.
    Then do these steps:
    1. Click for more details...
    2. Edit records
    3. Add or edit your biography text, fonts, etc.
    4. Advanced
    5. select HTML
    now you show HTML code which was broke by qrzcom server few days ago.
    6 Alt-A and cut all text. You have now clear window.
    8. Open Microsoft Word or any other text editor and insert text here.
    9. Replace /ed/http:/ to http://.
    10. Copy all text
    11. Insert new HTML code in your HTML window
    12. Update -
    13. Save
    I am do it for last two days about 20 times for my friends and all times it work.
    If you will have a trouble -please contact me direct by e-mail, OK?
    Good luck.
  4. G0LZX
    thanks for the replies guys, much appreciated
    ricky g0lzx/g1vwl
  5. G0LZX
    Vlad, just sent you an email, that code you sent me still doesnt work???
    the only thing showing up now on my qrz page is a revolving globe ????
    everytime i copy and paste the html code into my page it WILL NOT update??
    please help
    ricky G0LZX/G1VWL
  6. UA6JD
    You insert not full HTML code - just part of them.
    Look for my e-mail , OK?
  7. G0LZX
    Hi Vald, you don't understand.....
    i AM entering ALL the html text but EVERYTIME i update it it and save it it reverts BACK to the same code????
    i'm not new to html files i know what i am doing, the problem seems to be a bug in the system
    can i give you my passowrd for you to try and see what i'm on about
    cheers
    ricky
  8. DO4NW
    DO4NW Ham Member QRZ Page
    This also happens to my page since two or three days. The string "/ed/" is automatically added to the beginning of every external link.
  9. UA6JD
    Hi Helmut -
    Do you need your new workable HTML code without /ed ??
    Read my post below .
    If you will have a problems - let me know and I will send a new HTML code.
    It is very easy -less 5 minutes and your page will works as b4
  10. G0LZX
    many thanks vlad for sorting my page out but WHY couldn't I DO IT???
    i'll keep a check on it but many thanks for all your help :)
    regards
    ricky
