What are these connectors called?
Discussion in 'General Technical Questions and Answers' started by AF8F, Nov 25, 2015.
Tags:
  1. AF8F
    AF8F Ham Member QRZ Page
  2. KC9UDX
    KC9UDX Platinum Subscriber Platinum Subscriber Life Member QRZ Page
    "Molex connector"
  3. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    I have a pile of molex shells and pins. If you need any, let me know...but they're readily available from Digikey and the like.
  4. WB2WIK
  5. N3DT
    N3DT Ham Member QRZ Page
    That was easy. Now how many of you can identify this sex-less connector?
  6. W9GB
    Molex made 2 popular sizes of their Nylon connectors (based on pin size) since 1970s.
    Mouser, Digi-Key, Allied Electronics, Newark, and others carry. Radio Shack still sells Molex or a knock-off they import from Asia.
    You will find their connectors in countless American manufactured good (Japanese manufacturers use JST, a competitor to Molex).
    0.062"
    A power or signal interconnect system rated up to 5.0A per circuit with standard brass terminals.
    http://www.molex.com/molex/products...oducts&chanName=family&pageTitle=Introduction
    0.093"
    Molex's Standard .093" pin and socket power connectors are an industry standard connector system based on an .093" pin diameter. The terminals can be used in either crimp housings or crimp receptacles and are capable of carrying up to 14.0A (9.0A with the largest circuit size housings; 17.0A with high-current/low-force terminals).
    http://www.molex.com/molex/products...Title=Introduction&parentKey=power_connectors
    MOLEX Power Connectors (current production, series)
    http://www.molex.com/molex/products/group?key=power_connectors&channel=PRODUCTS
  7. WB2WIK
    Of course! General Radio 874. I use them all over the place.
  8. KL7AJ
    General Radio, of course!
  9. N3DT
    Now why would anyone use a GR connector unless you have one of those strange little GR VFO's? I wonder if anyone has a picture of them? I can't even remember how they were powered.
    http://www.pa4tim.nl/?p=4283
  10. WB2WIK
    I have a lot of GR gear, including an admittance meter, a signal generator, coaxial line stretchers, etc.
    It's very common in the industry. I must have ten pieces of equipment that use them, and GR to N adapters are also very common, so I have about twenty of those.
