ad: jefatech
W6/Handle: how to log?
Discussion in 'QRZ Site Community Help Center' started by KM6NQX, Sep 25, 2025.
  1. KM6NQX
    KM6NQX Ham Member QRZ Page
    I've had two contacts recently with foreign visitors to the US using the format W6/ and their call sign. If I simply log the contact with the call sign it looks like I've made a contact with someone in Germany or the UK when all I've done is talk to someone in San Francisco who was visiting from overseas. If I log the contact as W6/... I get an error that the call sign can't be found. So, I'm not sure what to do. Is there a correct way to log these contacts?
  2. WG7X
    WG7X Platinum Subscriber Platinum Subscriber QRZ Page
    W6/DX1DXX is the correct format. If your logging program doesn't accept that, try the old way: DX1DXX/W6. Make sure that there are no spaces between the W6/ and the actual call sign either way that you do it. If there is a space in between that will also cause an error because the program only sees the W6/ when it is in the front. If the W6/ is on the back, the program will only see DX1DXX and stop at the space.
    Most logging programs now accept the first one. If yours doesn't you need a better program...
    KM6NQX likes this.
  3. KM6NQX
    Thanks!
ad: Radioddity-1
