Hi, when viewing someone's log, it only shows the top 15 contacts, even though they have hundreds of contacts. There is no scroll bar or "next page" showing up as I would expect. I am using a android tablet if that makes any difference, and I have also viewed the page as both mobile view and desktop with no difference. I would like to be able to view more than the last 15 contacts. Ant ideas? Thanks, Tim
You are not utilizing the logbook for its intended purpose. A logbook is used to log the QSOs made by its owner. That information is private to its owner. The owner may opt to add a logbook tab to its callsign database page. If so, only the latest 15 QSOs will be partially displayed to indicate the latest time the owner has managed its logbook. Confirmations are based on the double-blind principle. Both parties to the QSO (you and your worked party) must each independently enter a record of the QSO in their logbooks. QRZ then automatically tests to determine whether or not the following data fields in each record match the other with regard to callsigns, band, mode, and UTC date/time within a 30-minute window. If so, a confirmation is indicated; if not, none is indicated.
Sorry, I do not agree with you and your arguments are pointless . I think there would have to be an option where you can chose you want to share the whole QSO book or not. Besides I'm very sure big majority of us would like to share!
I had a need to confirm a QSO time and was unable because of this limitation. And it is, a limitation.
No different than LoTW. If your data is correct and matches his data, a confirmation will result. But if either party "busted" some data, no confirmation. Being able to "peek into their log book" and make your data match his is considered cheating. Same exact system LoTW and Club Log use, among others. It's called "double blind" - either your data matches or it doesn't. Not a limitation at all. It's a DESIGN INTENT Dave W7UUU
I understand the cheat aspect. My scenario was the operator sent me a request to confirm, and my log did not include the contact, even though I remember it well as he lives about a mile from me. I guess I am not the type to consider fudging stuff and did not consider there are those that will cheat. Sadly. I feel sorry for them.
