ad: AlphaRF-1
Vertical trap re-build - sealants
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by W3NJ, Dec 21, 2009.
  1. W3NJ
    W3NJ Guest
    Hello,
    I'm re-building a multi-band HF trap vertical that has 2 damaged traps due to wind snapping the fiberglass coil forms. I've replaced the coil forms and have re-wound the traps (10 gauge wire) . The fiberglass fits inside the aluminum tubing and the maker originally used some very strong epoxy/glue to bond the fiberglass to the aluminum. I'd like to know what's recommended to achieve this same strength on the replacement. Also ,the original traps had heatshrink, which I'll be replacing (ordered some from Mouser this weekend...a bit late, but any cautions on this for outdoor use/UV resistance?). Wondering if I need to treat the heatshrink-to-aluminum contact area with any type of sealer.
    Any pointers on outdoor epoxies, glues, or sealants is appreciated! ( I do have some Gorilla Glue if anyone has inputs on using/not using it or Gorilla Epoxy)
    tnx es 73!
    Bruce - W3NJ
  2. N3JJB
    N3JJB Ham Member QRZ Page
    I'd try 3M 5200. It's an adhesive/sealant. Any marine store will have it. It has a little elasticity to it which can be important when attaching two different materials that will expand and contract at two different rates. They glue boats together with this stuff, it's strong.
    Terry
  3. W3NJ
    W3NJ Guest
    Thanks Terry for the recommendation. I'll ahve to stop by the local marine store or see if Lowe's/Home Depot carry it.
    Bruce - W3NJ
