ad: TinyPaddle-1
UTC Clock (for Win32)
Discussion in 'Contests, DXpeditions, QSO Parties, Special Events' started by KI4QFY, Nov 27, 2006.
  1. KI4QFY
    KI4QFY QRZ Member
    BTW, heres a freeware ZIP program... Make OR extract ZIP files.
    HTH,
    Andrew
  2. N7VQM
    N7VQM Ham Member QRZ Page
    Appears to run fine under WINE on Linux. I'm using Ubuntu Dapper Drake with WINE 0.9.25.
  3. KD4SM
    KD4SM Ham Member QRZ Page
    Thanks a lot. This is a useful application. Thanks again.
    Shane
  4. KI4QFY
    KI4QFY QRZ Member
    NP Shane, thanks for the feedback (and check the About box on the new version :blush: )
    Andrew
  5. KD4SM
    I saw that, Andrew. Thanks for the nod, but you've done all the work and deserve the credit. Again, its a nice program and good job. BTW, do you know of a ham around Roanoke whose call ends with a HP. He was able to get into the local repeater from there, and its located in Ashe County NC. Its around 100 air miles distance, but I forgot his call. Any ideas?
    Shane
  6. W6USC
    W6USC Guest
    thanks great little program-
  7. VE7NOT
    VE7NOT Ham Member QRZ Page
    Great program. My 60Hz clock varies up and down.
  8. K5GHS
    K5GHS Ham Member QRZ Page
    I know you find the ticking seconds annoying...but on my system with them enabled, the clock on the right seems to lose one digit. Course, if you get rid of the seconds its fine.
    Maybe next update just make the window a tiny bit wider? [​IMG]
    Otherwise, great program, have it autoload on startup now [​IMG]
  9. KI4QFY
    KI4QFY QRZ Member
  10. N4CAX
    N4CAX Ham Member QRZ Page
    Could a timer be added to the program?
    Works great so far.
    kg4yus
  11. K5CHF
    K5CHF Ham Member QRZ Page
    clock works great, thanks!
  12. KE5CAX
    KE5CAX Ham Member QRZ Page
    I have been looking for just such a clock. THANK YOU so much. the only think I could ask for is an analog face for the clocks but, that could be much later. analog is easier to see without my glasses.
    Ed [​IMG]
  13. KI4QHM
    KI4QHM Ham Member QRZ Page
    Good Program.
    Thank you
  14. K8MCN
    K8MCN XML Subscriber QRZ Page
    [​IMG] tnx --great small program-does just what i need!
  15. W9SK
    W9SK Ham Member QRZ Page
    What does your clock program use for time reference source? PC clock? Inet clock site? I am seeing a 4 min diff between Zulu on your clock and my wall-mounted WWV controlled Zulu clock.
ad: UR5CDX-1
