UREI BL-40 Modulimiter
Discussion in 'Amplitude Modulation' started by K4KYV, Jul 13, 2021.
  1. W3SLK
    W3SLK Ham Member QRZ Page
    K4KYV said:
    I'm glad I'm not the only one that noticed this Don. Many times I left my parts jobber, (I love that name of electronic parts stores!), wondering if I asked for the proper wattage resistors!
  2. W8KHK
    W8KHK Ham Member QRZ Page
    Don, considering the miniscule current required by the output amplifier transistors, I believe you will find that it is possible to size the wattage of the resistors such that they are small enough to fail in an open condition if there is a fault that would risk the power supply components, but, at the same time, exhibit no noticeable heating issues under normal operation. It would require quite a large current to cause significant heating in these 10 ohm resistors.
    An example comes to mind, when I performed a foot-in-mouth error when I was testing the series modulator tubes in the widow-maker breadboard setup. I connected one of my HP function generators to the grid circuit of the modulator driver tube. I forgot there was a DC bias pot connected to the grid, and I neglected to use a coupling capacitor. Fortunately, there was a 600 ohm, 1/4 watt resistor within the enclosure, in series with the output terminal, providing a 600 ohm source impedance. The resistor was vaporized by the bias supply!
    I did not have a manual for that device, so, when searching online, I discovered a reference in an HP journal, discussing new features (at that time) in the article. The last few lines of text indicated the instrument was inexpensive enough to be used in educational institutions, and it intentionally included a 1/4 watt fuse for the same reason - bonehead moves like I committed!
    WA3VJB likes this.
  3. K4KYV
    Definition of jobber: one that jobs: such as
    (1) : specifically : a wholesaler who operates on a small scale or who sells only to retailers and institutions
    https://www.merriam-webster.com/dictionary/jobber
    Years ago I set myself up a "consulting service", simply by printing a batch of business cards and letterheads. Numerous times it has enabled me to purchase items or subscribe to publications from outfits, including electronic parts suppliers, that had a policy "not to sell" to individual customers.
  4. K4KYV
    Looks like one of the op-amps in the BL-40 is bad, thanks to my carelessness. I received the rest of the components needed to finish repairing the audio output stage, and after installing them, looked down and discovered that I had forgot to turn the damned thing off before starting to unsolder components. When I tried it out, the amplifier now works perfectly, but the peak limiter section is dead. I suspect that a piece of solder wick I used to remove the old components managed to flick over and short something to one of the 18v rails or to ground.
    Traced it down to the negative-peak gain reduction IC. Fortunately, that one, an LM-318 high speed op amp is still available, but only in 8-pin DIP format while the ones in the unit are all 8-pin TO-99 (can type). Some of the other ICs and transistors are pure unobtanium, not to be found anywhere. I was dreading the thought of attempting to fabricate some kind of adaptor, when I found this company on line. They make a variety of adaptors such as TO-99 to DIP and vice versa. The one I need costs $2.50 each. I ordered several, just in case I lose another IC, or run into a similar problem in another piece of equipment.
    https://www.cimarrontechnology.com/product/browndog-020601a-dip8-to-to99-adapter
    WZ5Q likes this.
  5. WZ5Q
    WZ5Q Ham Member QRZ Page
    I've been using their products for years. You will not be disappointed in function or quality.
  6. K5UJ
    K5UJ Ham Member QRZ Page
    Thanks for the progress report Don; we're all looking forward to your return to the low bands. Kevin W9FMH asked about you last night and I told him what you were doing.
  7. W3SLK
    I have one of their equalizers. It was sitting in my friend's basement for years and sitting down in mine did it no good either. I need to return to the hamfests in search of the ever elusive 'roundtuit' so I can get started on a lot of these projects.
  8. K4KYV
    I can get on the air without the processor, but I don't have much incentive to do so when I turn on the receiver and the AM signals I hear are buried in static. I don't usually get out to the shack until well after sundown while most of the activity, at least the good readable signals, seem to be on in late afternoon and early evening. By the time it's fully dark, they've started rolling up the sidewalks.
  9. K4KYV
    Here it is a month later, and I still haven't got the BL-40 peak limiter section to work properly. Successfully repaired the audio section, and the RMS limiter function is OK. One of the problems is that most of the semiconductors inside are obsolete and hard to find or unobtanium. The ones in the peak limiter appear to be critical, and having to come up with usable substitutes is not easy, plus the serial crap-outs continue (I can now think of 9 unrelated major things round the house and shack to go south on me since this past February). Last week my audio generator died, and yesterday the 10x probe I use with the scope abruptly quit while I was using it. Fortunately I have usable substitutes. Still hoping to get it going before static season ends; it sucks trying to operate without any audio processing.
