ad: hrd-2
TYT MD380 Password Issue
Discussion in 'VHF/UHF - 50Mhz and Beyond' started by LA6PFA, Nov 5, 2017.
  1. LA6PFA
    LA6PFA Ham Member QRZ Page
    My MD380 is locked after doing a "upgrade" with a win application (MD380Tool (by KG5RKI))
    I did receive the tool and some files as a zip file from my friends.
    The instructions was to open a file named experiment.bin dated 11.09.2017
    (or 09112017.... maybe already my alarmbells should ring)
    I did run the "upgrade"..... and my MD380 now asking for password when startup
    I did try the 00000000 and 99999999 without any luck.
    Then I tried all the similar 1, 2, 3 etc.......
    Anyway; my TYT MD380 is now locked and for no other use than the trashcan.
    Any suggestions for the correct password would be appreciated.
  2. KA9JLM
    May be best to contact KG5RKI
    Good Luck.
  3. LA6PFA
    I dont believe KG5RKI got any part of this;
    The tool itself is working fine;
    Problem is the file named experiment.bin
    (Or me for my stupidity using the file)
    By e-mail I have asked TYT for a repair.
  4. KA9JLM
    Do you have a link to that bin file ?
    Good Luck.
  5. LA6PFA
    Sorry, no link... but got the file on my laptop.
    Might be info about a password inside the file, but dont know how to debug...
  6. KA9JLM
    With a filename like that, It is really hard to tell what version it is.
    Good Luck.
  7. LA6PFA
    I have asked TYT for a solution.
    If any answer from TYT I will post this.
    Stay tuned :)
  8. KA9JLM
    Is it still under warranty ?
    It would be great if they would help you with firmware that they did not release.
    Normally it is a "Do at your own risk" type of thing when using hacked firmware.
    Good Luck. Please do post their answer.
  9. N7DFL
    N7DFL Ham Member QRZ Page
    That should be a setting in the codeplug. Try opening the file in the MD-380 CPS software and see if you can fined it.
  10. LA6PFA
    The problem is that you cant program the radio from CPS without any password.
