TYT HT-7800 Data port pin outs
Discussion in 'General Technical Questions and Answers' started by ZS6BV, Aug 27, 2019.
  1. ZS6BV
    ZS6BV Ham Member QRZ Page
    I am looking for info on making a programming cable for the TYT HT-7800.
    There does not seem to be info on the internet. I need the pin outs for the data port.
  2. KF5FEI
    KF5FEI Ham Member QRZ Page
    Assuming you meant TH-7800, the manual says it is a "PC programming data port." I'd just buy a cable -- probably $15 or less.
  3. ZS6BV
    Yes TH-7800. The programming cables are not available here in SA. Would have to import it, our postal system is useless and then it will lie at customs for months. I have all the components to put one together. I just need the pinouts.
  4. KA9JLM
  5. KF5FEI
    Are they really using the USB-style connector as intended, tho?
    I have a Chinese DMR HT that came with a USB power cube and USB to charging stand cable, but the power cube put out 12 VDC. Not exactly kosher. So I boldly labeled the power cube as being 12 volts, and hot-glued the cable to it so there would be no mistakes.
  6. KA9JLM
    It seems that they are, The radio schematic matches the same pin out.
    I guess it is possible that the voltage is different, But the pinout is the same.
  7. VK3PBJ
    VK3PBJ Ham Member QRZ Page
    I just made a DIY programming cable for my TH-7800.
    The data port on the back of the radio is a standard mini-USB, but it needs a TTY interface, so you can't just use a standard USB cable.
    I used a USB-to-TTY serial cable, and a salvaged USB-A socket to connect a standard mini-USB cable to the data port. Simply connect the TX, RX, and Gnd pins from the TTY cable to the appropriate pins on the USB-A socket.
    I was then able to use Chirp to read and write to the TH-7800.
    PC <--> USB-to-TTY cable <--> USB-A socket <--> Mini-USB cable <--> TH-7800
    https://www.adafruit.com/product/954
    KA9JLM likes this.
