ad: KF7PMW-1
TS-520 VFO Doesn't stay on freq through range
Discussion in '"Boat Anchor" & Classic Equipment' started by K2HNL, Jan 12, 2018 at 4:12 PM.
  1. WB2WIK
    Used DG-5s are expensive, I understand.
    However there are more "modern" equivalent counters that are way cheaper and still adjust the display to read the actual operating frequency...probably $49 or so. Might be worth it. The new ones won't match the "Kenwood" look but are very functional.
    It's difficult to make a capacitor-tuned VFO hold calibration across 500 kHz; so difficult that Collins (and Drake, and even Ten Tec) went to PTOs instead a long time ago. The Collins PTOs have a camshaft inside, with cams tweaked one-by-one to adjust tracking and keep the dial calibration accurate across the band...very complicated, but it worked.
  2. KV6O
    KV6O Premium Subscriber QRZ Page
    Build your own:
  3. G3YRO
    G3YRO Ham Member QRZ Page
    If the VFO capacitor is similar to that usd in the FT101 VFO, you can get the VFO to track by bending the vanes . . .
    If you look at the outer vane of the moving part of the VFO vanes, you will see it is split into about 6 sections, so you can move that vane in and out slightly. This is to adjust the tracking of the VFO.
    Start at the end of the band where the VFO capacitor is fully un-meshed. Zero the dial against the calibrator at the 100kHz point..
    Now go to the next 100kHz point, and bend the first movable vane in or out to get it spot on . . .
    Then go to the next one, etc.
    It's a bit trial-and-error until you get the hang of it . . . but this is how to get your VFO to track across the band.
    Roger G3YRO
  4. K0MB
    K0MB XML Subscriber QRZ Page
    When my TS-520 was brand-spanking new the VFO didn't track perfectly.I just developed the habit of going to the nearest 25 kc point, and re-zero the dial to the calibrator. And this is what I would suggest you consider,
    KA9JLM and KP4SX like this.
  5. G3YRO
    Why make do, when you can make it work properly?
    When I worked for Yaesu, if anyone's VFO didn't track properly, I would fix it so it did !
    Roger G3YRO
  6. KA9JLM
    Everyone does not work the complete range of the dial.
    Kenwood made the Slip Dial adjustment for a reason.
  7. KI4AX
    KI4AX Ham Member QRZ Page
    Don't mess with the VFO Tracking and don't bend the Plates of the VFO. This is normal for the Kenwood TS-520. This is why they provided a 25 Khz Marker Generator - that's what the Marker is for; to calibrate that dial ring. It has to be calibrated every time you move more than 25 KHz (in theory) from the last frequency you calibrated it on. Refer to the Owner's Manual to learn how it works, how to use it, and how to keep the dial calibrated; it is very simple. Do NOT try to adjust the tracking of the main VFO and do NOT bend the Plates of the Main Tuning Capacitor - these are not your problem and most likely you will never get them right (again). Stop before your rig becomes FUBAR...
    Dan KI4AX
  8. G3YRO
    Well that's really crappy if the TS520 dial can't be made to track across the whole 500 kHz !
    The Yaesu FT101 series does it fine . . .
    And as I mentioned, if ever a rig WAS slightly out at one end of the band, it was pretty easy to adjust the variable capacitor to get it spot on. I did this on about ten rigs that we sold, out of the many thousands.
    (I'm pretty sure I did the same procedure on at least one TS520 . . . but it was a long time ago !)
    Roger G3YRO
ad: KG5DTX-1
