ad: Alphaant-1
To CW or not to CW? New ham - a few questions
Discussion in 'Straight Keys - CW Enthusiasts' started by NT4TC, Mar 2, 2017.
  1. NT4TC
    NT4TC Ham Member QRZ Page
    Hey folks. My name is Tom. I got my technician license a little over a year ago but then got sick and wasn't able to do anything with it (I had a stroke that left me legally blind - now permanently disabled and rather bored so...)
    Things are looking up and I'm testing for my general next Saturday.
    I am completely infatuated with the 'idea' of Morse code. Wondering if I might ask a few questions?
    #1. Is it worth it to learn CW? Still lots of ops using CW'? Plenty of QSO's to be had'?
    #2. Will a KX3 be enough? Considering a couple of issues...
    A. I'm in a very restricted HOA so I'll be using something like an Alpha-Antenna Complete Multiband Tuner free antenna, or a buddipole or (most likely) an EFHW4010 from myantennas.com that I can put up and take down when operating or take portable with me to the park.
    B. Nearing the bottom of the sunspot cycle, along with my compromised antenna situation, will not having a 100w rig be a huge detriment'? (My top alternative rig would be the Kenwood TS-590SG followed by the IC-7300)
    At any rate, I appreciate any hel- you guys might be able to offer.
    Tom - N7TGC
    2E0OZI, KE8EAS and AD5KO like this.
  2. WF4W
    WF4W Ham Member QRZ Page
    CW is still very active. And of all modes it is most suitable for low power and/or non optimal antennas as it will make it through the noise where voice fails.
    I am rather biased towards CW but objectively speaking, it is certainly viable for your situation and well worth learning.
    K6JJR and AD5KO like this.
  3. NT4TC
    Thanks! Should I look at a 100w rig or will the KX3 be enough'? (Obviously, in your opinion)
    Tom - N7TGC
  4. N2EY
    IMHO, you want 100 W capability. QRP is great and you can do a lot with it, but with a compromise antenna it's an uphill go.
    As for CW activity.....
    This past FD I went with a local 6A group. I was on the 40 CW team. We made over 1000 FD QSOs on 40 CW - more than any other band or mode in our group.
    Shall I post my "12 Tips" piece again?
    K6JJR likes this.
  5. NT4TC
    Dunno what that is but if it's relevant and will help this new ham, you can point me to it and I'll be happy to read it.
    Tom - N7TGC
  6. WR2E
    WR2E Ham Member QRZ Page
    Absolutely.
    Realistically, when you run QRP with compromise antennas you can expect that you won't be heard as well... but you WILL be heard. I work guys using the KX3 and similar antenna situations all the time.
    HUGE? I dunno... you've already got the KX3 ? Run with it and see how it goes.
  7. N2EY
    Here they are. I've posted this before, but to save you searching, here goes:
    Way back in the 1960s it took me about two months to go from zero to about 7 wpm. I did it by listening to other hams on the air - no tapes, records or computer. There are better ways now and you can probably get to 5 wpm or so in a month to 6 weeks, if you practice every day.
    In a few months after getting my Novice I was ready for 13 wpm, and in about a year, 20 wpm. And that was just the beginning.
    Dr. George Sheehan frequently said that "Each of us is an experiment of one". He meant that while there are general rules to learning new things, each of us has to experiment to find out what works best for him or her. For most things, there is no single "best" way for everyone. This is particularly true when it comes to learning skills.
    That said, here are 12 tips to learning Morse Code:
    1) It used to be that there were two main reasons for radio amateurs to learn Morse Code. The first was to actually use it on the air, while the second was to pass the license tests. The second reason has disappeared in the USA and several other countries.
    So it's important to understand what your goal really is: to become an Amateur Radio Operator who is skilled in Morse Code. That means learning a set of skills, not just the one or two skills needed to pass a one-time test.
    That skillset cannot be learned by reading a book, watching a video, using other modes to talk about them on the air, or participating in online forums. While those things help, they are not the core.
    The needed skillset can only be learned by doing, and it takes time, practice, and an active involvement on your part. This is what makes learning skills so different from "book learning" - and why some folks find it so hard to learn skills. You have to be actively involved - it doesn't happen passively.
    2) Set up a place to study Morse Code. This doesn't mean it's the only place you study code, just that it's optimized for learning it. A good solid desk or table with no distractions, lots of room to write, good lighting, and a good chair. Source(s) of code (computer, HF receiver, tapes, CDs, etc.), key and oscillator. Headphones are a good idea. I recommend starting out with a straight key, you may decide to go straight to paddles and a keyer. Regardless of what key you decide to use, it needs a good solid base and needs to be adjusted properly.
    3) Avoid gimmicks such as CodeQuick and printed charts with dots and dashes on them. Often such systems were designed to help a person learn just enough code to pass the 5 wpm test, but resulted in bad habits that had to be unlearned for practical operating. Morse Code as used on radio is sounds, not printing on a chart or little phrases. They may work for some people, but, in general, I advise against them.
    Learning to receive consists of nothing more than learning to associate a certain sound pattern with a certain letter or number. There are only about 41 of them to learn. If you could learn to recognize 41 words in a foreign language, you can almost certainly learn Morse Code.
    4) Set aside at least a half-hour EVERY DAY for code practice. Can be a couple of ten- or fifteen minute sessions, but they should add up to at least a half hour every day. That means every single day, not just weekends, holidays, etc. If you can do more than a half-hour some days, great! Do it! But more on one day does not give you an excuse to miss the next day.
    Some folks learn better if they do several short sessions, some learn better if they do it all at once. You have to find out what works best for you.
    Yes, you may miss a day here and there, because life happens. The trick is to keep such missed days to the absolute minimum.
    5) If you can enlist a buddy to learn the code with, or find a class, do it! But do NOT use the class or the buddy as an excuse to miss practice or slow down your learning. The buddy and/or class are a supplement to your study, not the center of it.
    6) Download and read "The Art And Skill of Radiotelegraphy". It's free and available from several websites. “Zen and the Art of Radiotelegraphy” is also good. Search out other code-oriented websites, articles, etc. and read what they have to say. But always remember they're not a substitute for practice.
    7) Practice both sending and receiving each and every day. Most of your practice time should be spent receiving, but the two help each other. Practice receiving by writing it down and by copying "in your head". I find a pencil and block printing works best for me; you may be better with a ballpoint, felt tip, etc. Or even a keyboard.
    8) A combination of the Koch method and Farnsworth spacing is probably optimum for most people. Read up on them, understand and use them – but remember they are tools, not magic. They can make learning the code easier but they will not make it automatic.
    9) Discontinue ANYTHING that impairs your ability to concentrate, focus, and learn new stuff. Only doctor-prescribed medications are exempt from this rule; beer is not exempt. Eat right, get enough sleep and enough physical exercise.
    10) Put away your microphones, stay off the voice radios - all of them. Besides the automated Morse Code generators, listen to hams actually using code on the air. Copy down what they send. Have Morse Code playing in the background while you do other things (but don’t count that as practice time). Learn how hams actually use code. When you get to the point where you can send and receive code, even slowly, get on the air and start making QSOs. Get involved in CW contesting, rag chewing, DX chasing, etc. Remember that you are learning Morse Code to be a Radio Operator, not just to pass a test.
    11) If your HF rig doesn't have a sharp filter (400-500 Hz), get one and install it. Read the manual about how to use the rig on CW; usually the default settings are optimized for SSB. Best operation usually requires turning off the AGC, turning the RF gain down and the AF gain up. The S-meter and AGC won't work under those conditions but that's no big loss; they’re not all that useful on CW anyway.
    12) Keep at it. There may be times when it seems as if you are making no progress, and times when you make rapid progress. What matters is that you keep practicing every day. Nobody was born knowing the skills you're trying to learn.
    A bit of work? Sure it is, but well worth it, because all those steps make learning the code easier. And the work is trivial compared to what you can do with the skills once they're learned.
    But a person has to be willing to do what's required. And they have to actually do those things.
    Good luck!
    73 de Jim, N2EY
    WC3T, KB2SMS, KU4X and 2 others like this.
  8. NT4TC
    I do not yet own any HF transceiver. I will be buying my first one when I pass my general test.
    Tom - N7TGC
    KB2SMS likes this.
  9. NT4TC
    Jim, that was - awesome. Thank you, Sir.
    Tom - N7TGC
    N2EY likes this.
  10. N2EY
    You're welcome.
    Now the trick is to follow the tips.....and find out what works best for you.
    And remember this:
    If you're like most people....
    By the age of two or so, you learned to walk and talk and understand your first language.
    By the age of four or so, you learned to recognize and repeat songs
    By the age of six or so, you could read and write.
    All of which are far more complex skills than basic Morse Code.
    KU4X, KF4SCI and KS3O like this.
