ad: w5yi
Time signal intruder
Discussion in 'Ham Radio Discussions' started by KA2FIR, May 27, 2018.
ad: DLSpec-1
  1. KA2FIR
    KA2FIR Ham Member QRZ Page
    Hi,
    The past few days I've been hearing this time signal that jumps in frequency within the 17m band. I heard this same signal late last winter in 20m and 40m bands as well.
    This youtube recording was made by someone else in NJ after seeing my 40m spots. Same signal just different band.
    Have you heard this signal?
    Tnx,
    Mike
  2. K9ASE
    K9ASE XML Subscriber QRZ Page
    It might be some sort of radar
    W5TTW and WZ7U like this.
  3. WZ7U
    WZ7U Ham Member QRZ Page
    Agreed. Or a good buddy messing with people ;)
    KA4DPO and K9ASE like this.
  4. W5TTW
    W5TTW Ham Member QRZ Page
    It's nothing nefarious. I recognized the sound and contacted my buddies at the Nelson Institute of Marine Research in Santa Barbra to confirm. The Seaview is conducting advanced sonar tests proximal to Cape May, NJ. (Just a precaution. There's been a lot of Chinese naval activity in the Atlantic.) They said that they would apprise Chief Sharkey that it's interfering on 40m. The Seaview floats a comms buoy every 8 hours, so it shouldn't take long to mitigate.
    W1TRY and K4PIH like this.
  5. K2CD
    K2CD Premium Subscriber QRZ Page
    You can add 30M to bands it's been showing up on regularly. I've been hearing it pretty much every day, somewhere or another since January.
  6. K2CD
    K9PG in Illinois was hearing in Illinois with his antenna disconnected. It was S9 +10 in Pennsylvania here and full scale up by him. This was on 20 meters way after sunset and not a single other signal was on the band. It stayed audible all night and was still there when I checked after daybreak. I think this was back in February. Very strong stuff.
  7. W0PV
    W0PV Ham Member QRZ Page
    Have been hearing if for several months. Heard it today on the top of 20 meters.
    Here is a clip when tuned to 14.309 Mhz USB on Monday 2018-5-28 @ 19:50Z.
    https://instaud.io/2f0t
    That was a little over 60s. Note the "double tick" now and then. It stopped for awhile shortly after that clip. Then a little over a minute later it started doing intermittent single ticks, spaced at seemingly random intervals. It kept going with some relatively long quiet periods with just one or a few ticks. I got bored and spun the dial after 20 minutes.
    I'm guessing its some sort of new type of spy coded numbers transmission, counting ticks or spaces between intervals or with sync to the top of a minute (like FT8 ;-)
    73, John, WØPV
    K2CD likes this.
  8. W0PV
    I notice now it is simultaneously xmitting up 5 khz on 14.314 (USB) too. Some kind of differential pulse FM or ? No dual watch so I can't listen both places at once.
    I looked at it on the waterfall in WSJT-X and see its producing about a 1000 Hz demod tone in my USB selected receiver, so that means its pulses are probably centered on 5 Khz spacing, ie, 14305 and 14315 Khz.
    On the waterfall the audio signature seen is actually quite "fat", ie, its not a thin CW tone line, more like about 100 Hz or slightly less broad (slightly more then an FT8 signal). Don't have an oscilloscope handy so can't measure how long the duration of a burst is. Could be some digi data buried in that though I bet.
    It would be fun to track it longer term with a SDR that can look at more of the spectrum at one time. And to see what is contained in those short ~100 Hz wide pulses.
    73, John, WØPV
    KL4EJ and K2CD like this.
  9. KA0HCP
  10. W0PV
    I reported this to IARU Region 2 Coordinator Carlos Beviglia, LU1BCE. Sent them the audio clip and description. Let's see if their Intruder Watch group can ID it or come up with some info.
    K2CD and NK2U like this.
ad: MultusSDR-1
