Thoughts on grounding plate
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KI5AAI, Jun 14, 2018.
  1. KI5AAI
    KI5AAI XML Subscriber QRZ Page
    I am going to install the polyphasers and antenna switch this weekend. The entrance panel I have has an aluminum plate in it (1/8" thick). I prefer copper. I have some copper grounding plate left over from an old project. It is 1/16" thick.
    Option A: Just use the copper plate. The only thing about that is that it is not very thick and may bend or move with all the polyphasers and cables on it.
    Option B: Cut a piece of the copper and put it over the aluminum plate. I have enough for front and back. I was going to spread Noalox in between if I do that. This would give me a good copper grounding plate and very durable.
  2. NN4RH
    Copper in contact with aluminum can result in corrosion exposed to the outdoor environment.
    The 1/16 inch thick copper is plenty thick by itself for the grounding purposes. If it were me, I'd just use the copper. If you are concerned about it not being stiff enough, screw it down to some wood, plastic, fiberglass, etc.
    AJ5J likes this.
  3. KI5AAI
    Or, I could just double up the copper :). Thanks for the input.
    AJ5J likes this.
  4. KD0CAC
    KD0CAC Ham Member QRZ Page
    It all depends on what is available , and any load issues .
    You could use contact adhesive on a peace of plywood , the issue would be if the copper sheet is able to carry the current --- think of PCB's .
    AJ5J likes this.
  5. WA4SIX
    WA4SIX Ham Member QRZ Page
    Find a local water jetting or machine shop. I just got 1/4" X 1.75" X 4'L copper, that was scrap from a waterjet job. Also, the 1/4X1/4 leftover parts (About 15 linear feet). $30. Cheaper than scrap value.
    Ed
    AJ5J likes this.
  6. AJ5J
    AJ5J Ham Member QRZ Page
    Like this?
    K9ASE likes this.
ad: Amateur-1
