ad: Hitched4Fun-1
The Real-Time Monitor Every Ham Needs de NØIDX
Discussion in 'Amateur Radio News' started by N0IDX, Apr 23, 2025.
  1. N0IDX
    N0IDX Premium Subscriber QRZ Page
    TalkBack Pro by NØIDX – 100% Real-Time TX Audio Monitoring
    Key Features:
    · True Inline “Talkback” – What you hear is what you transmit!
    · Compatible with Yaesu, Icom, Kenwood (base and mobile: POTA, SOTA, DXpeditions, shack ops)
    · Dedicated Monitor Level Knob and blue power LED for instant control
    · Crystal-Clear Monitoring – Never overdrive your rig again
    · Easy Inline RJ-45 and 3.5mm Jacks for mic and monitor connections
    · USB Powered – Use it anywhere, no batteries required
    · Plug-and-Play – Works with standard cables; built for rugged travel and field operations
    · Legendary NØIDX Quality – Designed by a DXer, for DXers
    · Made in the USA – Designed, tested, and hand-checked by Glenn, NØIDX
    · Launching on Kickstarter – Reserve Yours Soon!
    About the Project
    Hi - I’m Glenn, NØIDX.
    I’ve had fun bringing IDXA T-shirts to market and designing a circular feed dish for AO-40, but my latest project is TalkBack Pro—a device that I believe will change the way all amateur radios are designed. For decades, radios have lacked a vital feature: the ability to truly hear your transmitted audio in real time, exactly as it goes out on the air.
    As a DXer with over 40 years of experience, I’ve always wanted to hear my actual transmit audio. Some modern radios, like my FTDX-5000MP, have this with a MONI button, but many classics (like the FT-857D) do not. When you transmit, you’re essentially “deaf” to your own audio—you have no way to know how you sound on the air. TalkBack Pro fills this gap.
    Plugged into your rig, TalkBack Pro lets you hear your processed audio in your headphones, just as others hear it. Instantly monitor mic gain, processor levels, proximity effect, and more—no more guesswork, no more “blind” on-air checks or expensive monitors. It’s USB powered and compatible with most radios featuring an ACC or similar port, and of course, it’s tailor-made for my own FT-857D.
    This is not a cheap toy. I’ve partnered with a professional electrical engineer, designed a custom PCB, and developed a tough, high-quality 3D printed enclosure using premium materials. Every unit will be hand-checked by me here in the USA.
    Production starts in June—get on board at Kickstarter when we launch!
    Benefits
    · No more “blind” transmissions or on-air complaints
    · Adjust your audio chain in real time—see, hear, and fix problems instantly
    · Ideal for POTA, SOTA, contesters, DXpeditions, and any ham who cares about quality audio
    · Lightweight, durable, and built for the field—no offshore junk
    Thanks for supporting real innovation by real hams.
    —Glenn, NØIDX
    WV3K, W2WRX, W6ACC/SK2025 and 14 others like this.
  2. KC3WUT
    KC3WUT Ham Member QRZ Page
    This is a great idea. I really would like to know how I hear when I make a QSO.
    KI4YZN, PU2LQX and KF2ZZ like this.
  3. KF2ZZ
    KF2ZZ Premium Subscriber QRZ Page
    Hi.
    Great idea...
    A couple of product suggestions:
    1) Create this unit with a single automatic Voice Keyer (20-30 second recorder) similar to the the MFJ-434B, so I can record my voice in HD audio, key up and play. Better than calling CQ endlessly.
    2) You need an good internal battery which would be user replaceable. Too many cords.
    Good luck! I'll be watching. I could be a beta tester, as well.
    :D
    AK5B, KC1TMT, N6JSX and 1 other person like this.
  4. N0IDX
    It is a flexable design. You can use an Amazon Y-cable and split the acc 6 pin din for digital use. This is a "Patent Pending" design files in USTPO.
    AE0HQ likes this.
  5. N0IDX
    Good idea. For now uses usb to power the unit. Very low draw. You could use a battery pack to make it packable.
    N6JSX, AE0HQ and KF2ZZ like this.
  6. KF2ZZ
    An internal battery with easy access would be a major plus - alkaline cells or rechargeables.
    What about the microphone feedback loop from the speaker?
  7. N0IDX
    Yes you get audio the same way as the big rigs, you have to adjust any feedback out accordingly.
  8. KF2ZZ
    Then it would be difficult to do in real-time.
    Have it record audio in HD (high sampling rate) until the TX is complete. Then enable it to play back.
    :D
    HA3FLT and AE0HQ like this.
  9. W4JCW
    W4JCW Platinum Subscriber Platinum Subscriber QRZ Page
    Add an XLR input/output
    W2WRX and AK5B like this.
  10. N0IDX
    Yes, these plugs will be included in future porduction runs. Everything depends on demand at this point.
  11. W4JCW
    I'd be interested in one...keep me posted please
  12. KJ7LVZ
    KJ7LVZ Ham Member QRZ Page
    So this isn’t demodulating RF? It is going between your microphone and your transmitter?
    HA3FLT, W4BSS and W0PV like this.
  13. K5YDD
    K5YDD XML Subscriber QRZ Page
    If it only monitors between transmitter and microphone, then it really is a microphone checker with no feedback as to how your transmitter's circuitry is modifying audio.
    HA3FLT, KO7T, KR3DX and 14 others like this.
  14. W6EM
    W6EM Ham Member QRZ Page
    Nice mini condenser mic "checker." It reminds me of headset monitor amplifiers used in professional audio mixer boards. Separate monitor level controls independent of mic output level. But, if you want to use with both magnetic and condensers, you'll need isolation and probably amplification for dynamic elements. Major difference in mic output levels as well......
    Also, no USB port connection or cable with USB plug.
    RJ-45 jack would be where? Not shown in photo.
    K0UO likes this.
  15. WA6VVC
    WA6VVC Ham Member QRZ Page
    What am I missing here...hear?? Twenty two days ago would make more sense.
    K1APJ, HA3FLT, AK5B and 1 other person like this.
