The NØPU Big Quiz
Discussion in 'General Technical Questions and Answers' started by N0PU, Jan 9, 2003.
  1. AE4FA
    AE4FA Ham Member QRZ Page
    Inductive reactance increases with frequency (2PiƒL), while capacitive reactance decreases with frequency (1/2PiƒC). That’s why there’s only one frequency where a given inductor and capacitor in a circuit will cancel each other’s reactance. ƒ has no effect on resistance.
  2. N0PU
    N0PU QRZ Member QRZ Page
    </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ae4fa @ June 08 2003,21:05)</td></tr><tr><td id="QUOTE">Inductive reactance increases with frequency (2PiƒL), while capacitive reactance decreases with frequency (1/2PiƒC).  That’s why there’s only one frequency where a given inductor and capacitor in a circuit will cancel each other.  ƒ has no effect on resistance.[/QUOTE]<span id='postcolor'>
    Right...
    FA: 10 points
    Question 425
    What is the formula for frequency of a tank circuit. [Give both forms!]
  3. AE4FA
    ƒ = 1/2Pi(SQRT LC) and ƒr = 1/2Pi(SQRT LC). There are some others, too, with some small modification of the way “resonant frequency” is designated.
    That’s probably not what you meant, though. There’s a shortcut that involves substituting the actual value of 1/2Pi, since it never changes – it’s always 0.159.
    So, the second form of the formula becomes ƒr = 0.159/(SQRT LC).
  4. AE4FA
    Okay, got lost in the notation – again. Harry knows that’s a weak point with me. Let’s try this:
    ƒr = 1/(2Pi*(sqrt(L)*(sqrt&copy;))
    And, substituting 0.159 for 1/(2Pi):
    ƒr = 0.159/(sqrt(L)*sqrt&copy;)
  5. N0PU
    </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ae4fa @ June 09 2003,09:44)</td></tr><tr><td id="QUOTE">Let’s try this:
    ƒr = 1/(2Pi*(sqrt(L)*(sqrt©))
    ƒr = 0.159/(sqrt(L)*sqrt©)[/QUOTE]<span id='postcolor'>
    Right...
    FA: 10 points
    Note: Use square brackets to avoid the dumb icon junk on the board... ie. f = 0.159 / sqrt[L * C]
    Question 426
    If you have a tank circuit with a 0.01 uF cap and a .01 mH choke what would the resonate frequency be?
  6. AE4FA
    ƒr = 0.159/[sqrt[L]*sqrt[C]]
    ƒr = 0.159/[sqrt[10*10^-6]*sqrt[10*10^-9]] = 502802Hz
    ƒr = 502.8Khz
  7. AE4FA
    ƒr = 502.8Khz
    And
    ƒr = 1/[2Pi*[sqrt [L]*[sqrt [C]]] = 503290.9
    ƒr = 1/(6.28*[sqrt[10*10^-6]*sqrt[10*10^-9]]] = 503290.9
    ƒr = 503.3Khz
    So, let’s round it to 503000Hz or 503kHz
    That’s probably a better answer.
  8. N0PU
    </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ae4fa @ June 09 2003,10:37)</td></tr><tr><td id="QUOTE">ƒr = 0.159/[sqrt[L]*sqrt[C]]
    ƒr = 502.8Khz[/QUOTE]<span id='postcolor'>
    Right...
    FA: 10 points
    Question 427
    If a tank circuit has a given resonant frequency will X be capacitive or inductive as frequency goes up? as frequency goes down? Why?
  9. AE4FA
    As ƒ increases, X will be more inductive. As ƒ decreases, X will be more capacitive.
    XL = 2PiƒL and XC = 1/2PiƒC
    Inductive reactance increases with frequency; Capacitive reactance decreases with frequency.
  10. N0PU
    </span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ae4fa @ June 09 2003,12:55)</td></tr><tr><td id="QUOTE">As ƒ increases, X will be more inductive.  As ƒ decreases, X will be more capacitive.
    Inductive reactance increases with frequency;  Capacitive reactance decreases with frequency.[/QUOTE]<span id='postcolor'>
    Right...
    FA: 10 points
    Question 428
    As the input frequency goes away from the resonant frequency of a tank circuit what happens to voltage and current through the circuit? Why?
