The Ham Nation Pine Board Project
Discussion in 'Amateur Radio News' started by K9EID/SK2024, Mar 8, 2017.
  1. KE0EFX
    KE0EFX Ham Member QRZ Page
    Also looking forward to the latest episode! Bob Heil put a photo of his mic pre-amp on E-Ham the other day to whet our appetites.
    I got the power supply done; it was really fun! It shows 190 volts at the output terminals.
  2. VE3LYX
    VE3LYX Ham Member QRZ Page
    I see someone mentioned on the U tube site that they wanted a CW rig as well. I built one yesterday afternoon and just worked K4WOP with it. Same tube I used for Bob's project. 7 or 8 parts total.
    donVE3LYX
  3. G3YRO
    G3YRO Ham Member QRZ Page
    Just read through this thread . . . sounds like a lot of fun !
    However, I built stuff like this 50 years ago, so probably won't be doing it again.
    Back in those days, everyone here in the UK was on 160m (and most on AM or CW), so it was a good band for simple projects and local contacts.
    One of the first transmitters I built (when I was 12) was a single EF91 VFO . . . It was powered using the 250V HT and 6.3V LT tapped off my receiver (WW2 surplus CR100) - something you guys might consider, to save building a PSU.
    I didn't even have a tuning network on the output, just connected my 160m end fed half-wave aerial straight to the RF Choke fed anode (via a cap!) - was probably a reasonable match. Considering it was a VFO, surprising it didn't chirp when keyed. (I guess the HT voltage was pretty stable). My best contact was nearly 200 miles away!
    One suggestion though . . . if you guys put a Carbon Microphone (from an old telephone or a WW2 transmitter) in the cathode lead of the modulator valve, you shouldn't need an extra Mic Preamp valve. (do make sure it's insulated though !)
    Roger G3YRO
  4. VE3LYX
    The audio from the set as he showed it is quite a bit above a carbon mic in the cathode lead (which will make audio if that is all U want) The supply though is a good bench supply although I did mne for higher voltage. The whole point is to get folks building and understanding I believe. Me, I did it for fun. (and it is.)
    The power stealing from an rx is a neat trick and I have two such CW rigs here.
    donVe3LYX
    Can't find last night episode on you tube. HELP!
  5. KE0EFX
    Apparently they haven't posted last night's video yet. He sure is dragging this project out...
  6. VE3LYX
    Yeah, mine is done and working well. But still I would like to watch it. I listened to some on 5086 but it was after Bobs part.
    Tnx for the heads up. Ur right,. Goes too slow & interest will vanish.
    donVE3LYX
  7. KE0EFX
    Nothing at all about the Pine Board Project this week; technical difficulties with Bob Heil connecting into the show.
    Hey, Don (VE3LYX), would you post a schematic of your transmitter section using the 12bh7 tube? I guess I'm not googling the right term/phrase but I can't find a schematic that looks like it would come after the mic pre-amp that uses a twin-triode. I'd like to better understand where we're going if/when Bob Heil get's there with this project.
  8. KF5FEI
    KF5FEI Ham Member QRZ Page
    Amen. It took Spock less time to build a tube computer on Star Trek.
  9. KE0EFX
    AF6LJ likes this.
  10. KD8YQC
    KD8YQC Ham Member QRZ Page
    There's a technical section for this project in the Homebrew and Kit Building section. You should post this question there.
  11. KE0EFX
    My apologies, I posted my question in the Homebrew and Kit Building forum...
  12. WB4OKM
    WB4OKM Ham Member QRZ Page
    Is the parts list listed here, or a link to it?
  13. KE0EFX
  14. WN1MB
    WN1MB Ham Member QRZ Page
  15. VE3LYX
    There is no schematic change. A 12bh7 is wired exactly as its 12ax7 12ay7 etc cousins except it just makes more power because it was designed for a heavier service app. In octal similar is a 6sn7 can be subbed with a 6bl7 with the same result. The b tubes were used as sweep tubes in TV but pinout is the same as their cousin tubes.
ad: MLSons-1
