The 10m splintenna, or "A cautionarie tale for younge hams"
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KC3JIN, Dec 7, 2017.
  1. KC3JIN
    KC3JIN Ham Member QRZ Page
    Remember, remember. When trimming for SWR, it' s always easier to trim more off than put more on.
    Observe my converted CB vertical and weep. The tip was held in by a little hex nut, that I loosened to trim it and then tightened again. This was my mistake - on future trimmings the tip was resting on the nut instead of on the channel bottom and being retained thereby.
    My fix was a little nubby of 18AWG from the core of a piece of TV coax (rg58U). Once we got *back* into the ballpark I wrapped it with medical tape.
    SWR sits pretty from 28.3 to 29.15..ish.. but I feel a lot more comfortable showing it off as a cautionary tale than a brag :) splinttip.JPG uprightenna.JPG
  2. KB4QAA
    Solution:
    1. Use a file or grinder to remove chrome layer and expose underlaying copper layer. Be careful as not to go through copper to the base steel.
    2. Solder wire to whip.
    3. Cover solder joint with shrink tubing; dual wall (adhesive) is ideal.
    KC3JIN likes this.
  3. KC8VWM
    KC8VWM Moderator Volunteer Moderator QRZ Page
    You can get a replacement whip.
  4. KB2WVO
    KB2WVO Ham Member QRZ Page
    good reminder.
    i know i forget sometimes. even with wire antennas. i have to catch myself.
  5. NH7RO
    NH7RO Ham Member QRZ Page
    Or make your own out of #12 ga wire: put one end in a vise, the other into a drill chuck, twist for a few seconds until straight...voila!
    Brand new whip from the hardware store.
    "Splints? Bandages? My antenna doesn't need no stinkin' bandages!"
    KC8VWM likes this.
  6. KC3JIN
    Relevant to my interests! Is it the twisting that straightens it?
    Many thanks to all for your wisdom. And condolences :)
  7. NH7RO
    Takes the kinks right out and makes the wire stiff. Stretching will accomplish the same thing but I always find the drill-vise method easy and expedient.
    Jeff
  8. K7JOE
    K7JOE Ham Member QRZ Page
    can you open the base and re-adjust the coil tap... no need to replace the whip..
  9. K0RGR
    K0RGR XML Subscriber QRZ Page
    This is where really strong alligator clips come in handy. The large kind, like those from Justrite will hang on in any wind. Just solder on a piece of stiff wire. I used this when I was doing CW mobile with Hustler whips to load the antenna down into the CW band with the clip on - phone band without it.
    KC3JIN likes this.
  10. KJ4YEV
    KJ4YEV Premium Subscriber QRZ Page
    Where's your antenna stretcher?
ad: w5yi
