Tektronix style terminal strips
Discussion in 'Homebrew and Kit Projects' started by W9GB, Mar 12, 2010.
  1. W9GB
    If you read the Collins restoration article
    Rebuilding the Collins 516F-2 Power Supply by Jim Garland, W8ZR
    http://www.w8zr.net/vintage/tcvrs/516F2 Rebuild.htm
    you may have noted that Jim used silver-ceramic terminal strips that he salvaged from old Tektronix oscilloscopes.
    He used several to build and mount the two diode rectifier banks as well as to hold the new capacitors and voltage equalizing resistors.
    Parts Connexion in Canada, now sells a reproduction of these Tektronix style terminal strips
    in FIXED and ADJUSTABLE height versions. Suitable for your next restoration project!
    http://www.partsconnexion.com/terminal_connex.html
    Parts Connexion
    5109 Harvester Rd, Unit B2
    Burlington, Ontario
    Canada L7L 5Y4
    HOURS OF OPERATION:
    10am-6pm (Mon-Fri) EST
    Toll Free: 1-866-681-9602
    Local: 905-681-9602
    FAX: 905-631-5777
    w9gb
  2. K7RQ
    K7RQ Subscriber QRZ Page
    If you use these strips it's important to use solder that has a small amount of silver alloyed into it (which Tektronics did) to prevent the process from lifting the silver coating off the ceramic. My old RadShack paper catalog showed it as part numbers 64-013 and 64-035.
    Hal
  3. W9GB
    Correct.
    Many older Tek scopes had a small loop of silver alloy solder inside for that specific purpose.
    You can also use Kester Pocket PaksĀ® exclusively available through NTE Electronics dealers.
    These are usually $ 2 to $ 3 USD per pocket tube
    http://www.nteinc.com/kester/pocketpak.html
    NTE # 83-7145-0415
    SN62 / PB36 / AG02 Elec. Silver Solder Pocket PakĀ®, 0.020 dia.
  4. K8ERV
    K8ERV Ham Member QRZ Page
    Here is a poor man's version. Any one ever see these?
    TOM K8ERV Montrose Colo
  5. W9GB
  6. K9STH
    ERV:
    Collins used those types of strips in the 75A-1 receiver and Heath used them in the TX-1 Apache.
