Tecsun Shortwave radios
Discussion in 'Amateur Radio Equipment Reviews' started by KW4TJ, Oct 29, 2003.
  1. KW4TJ
    KW4TJ Ham Member QRZ Page
    The radio's construction is high quality and performance itself is great - Using a sloped dipole at 15
    feet with a tuner (Ant Gain switch turnded down on radio) I heard all the stations I could hear on
    my TS-430S ham rig and the audio quality was much better although not as mellow as larger radios.
    A few images appeared but otherwise little overload. Very little background noise for a portable.
    All India Radio 11620 came in well - much better than with the Grundig S350. Also I heard several
    Middle Eastern and Eastern Europeans broadcasts. I haven't really tried out AM or FM yet but but
    both have good audio. The Low tone setting works best for me.
    I had a few problems with the radio the first day. The radio would turn off after being on only
    10-20 seconds. After half an hour of trying various things it turned the out batteries that came
    with radio died (after only 3 hours). The AC adapter does not work but it could be because
    I don't have 220V here. It took awhile but I finally figured out Sys Set features and I loaded
    several memories. To load memories, you need to set the page number first (default is P 1)
    on M Page button - this is best explained near the beginning of the manual. (By the way the
    maual for the YB-550PE [same features as PL-200] is downloadable at the Eton website -
    the PL-200 manual is in Chinese). After that forget the manual - it will mess you up - very
    confusing! Just tune to the frequency you want then press MEM EDIT and the frequency
    will automatically load at the first available memory - (P 1 01) after 3 seconds.  Deleting
    memories is easy also. Other explanations in the manual are easier to understand.
    I like the radio alot but it really doesn't have the feel of an analog radio that I was hoping for.
    When you tune up or down the bands using the tuning wheel or the UP DOWN 5 khz keys you
    hear a slight electronic clicking noise which gets to you after awhile. Also it takes several turns of
    the thumb wheel to go from the bottom to the top of each band - so I find myself pressing
    buttons about 95% of the time. I've always believed that digital sets are actually less user
    friendly than analog sets, despite all the extra features - they sure don't feel the same - just
    my opinion.  Maybe I'll feel diffently after using it awhile. 4 1/2 stars
