ad: SDRKits-1
Tank circuit for two tubes
Discussion in 'Amateur Radio Amplifiers' started by WB5NEN, Sep 30, 2019.
  1. WB5NEN
    WB5NEN Ham Member QRZ Page
    I'm learning. I can calculate values for a Pi network tank circuit using the method in Eimac's "Care and Feeding ..." That's for a single tube. Now, to show my ignorance (but that's how to learn). How do I calculate for a pair of tubes in parallel? That is, how do I modify my C and L values for a pair of tubes?
  2. K7TRF
    Wouldn't you just start by recalculating the impedance at the anode circuit of the pair of tubes which off the top I'd expect to be the same peak RF voltage over twice the single tube RF peak current with two of the same tube in parallel, biased the same and driven by the same signal. IOW, half the impedance of a single tube.
    So, two matched tubes should draw twice the RF current of a single tube and it's RF voltage over RF current that determines the impedance at the anode(s). That's the input impedance to your PI network, I assume the output impedance is 50 ohms and you select the Q but something in the range of 10 to 20 seems pretty typical for loaded Q in an tube amplifier's PI network.
    KK4RSV likes this.
  3. WB5NEN
    Is it really that simple? Peak RF voltage (unchanged) divided by twice the Peak RF current (for two tubes). I had wondered. So it looks like you confirmed. Thank you. And you have a nice station. I admire the TR4CW you have.
  4. K7TRF
    Thanks!
  5. WB2WIK
    "Tanks for the mammaries..." Bob Hope's theme song.:p:)
    "I need to know the tank Q."
    "You're welcome."
    WA7PRC likes this.
  6. KD2ACO
    Goodness, Steve...
    That’s two “tubes.”
    K2XT likes this.
  7. N8FVJ
    N8FVJ Ham Member QRZ Page
    Amateur Radio Handbooks have calculation tools. I would pick up a pre 1970 year.
  8. KM1H
    KM1H Ham Member QRZ Page
  9. W9WQA
    W9WQA Ham Member QRZ Page
    im far from an expert on this. yrs ago i struggled with handbook formulas and nomographs for pi net
    inductance info. it seems that a 2nd tube cut plate resistance in half so i was uncomfortable testing with one 813 and then a 2nd.
    i know that i had to mess with taps on the pi coil even though it would tune with thc cap at many tap points. its probably why my hb 2x813 amp is lazy above 20 meters but its an ongoing labor of love.
    whomever inherets it may do better. i can whistle up appx 800 watts on 160 to 40, less on 20 and above
    btw i do have 3 sockets wired in but 3 813's did not do well !!
  10. KM3F
    KM3F Ham Member QRZ Page
    Basicly there is double the plate current assuming 2 tubes vs 1, half the plate load resistance, double the Plate interelectrode capacity to account for.
    813s were never very efficient above 20m.
    Plate capacity to ground becomes a large part of the tuned output circuit you can't do anything about.
ad: vanity
