ad: QSKLLC-1
Stereo TRS plug for straight key
Discussion in 'Straight Keys - CW Enthusiasts' started by KD2RDG, Jan 20, 2021.
ad: QSOToday-1
  1. KD2RDG
    KD2RDG Ham Member QRZ Page
    I figured out why this is a good idea.
    Get a $2 headphone splitter Y cable and you can set up a paddle and a straight key into the same jack. Then just switch the internal keyer off and on to change between them.
  2. DD5RK
    DD5RK Ham Member QRZ Page
    I have a 5x splitter for audio cable. I have a straight key, a bug and a paddle in parallel.
  3. KD2RDG
    So far I have resisted buying a bug. We'll see how long that lasts. :D
    K0UO likes this.
  4. KG7WGX
    I've been doing that for two years. It is a good idea.
    Also, for those who have transceivers with PF (programmable function) keys, you can generally set one up to take you to the menu item for changing the key type with a single press.
    For the KX3, the knob does not not "wrap around", so a quick CW spin defines Hand and a CCW spin defines Tip=Dit. (And anybody using a L-hand paddle would have to pause in the middle to set that.)
  5. KG7WGX
    I have too many keys. It took three years, and I thought I was done.
    I haven't bought one since July, and that one was a bug.
    I tell myself, "I can quit buying keys any time I want to." ;)
    KD2RDG likes this.
  6. PU2OZT
    PU2OZT Ham Member QRZ Page
    Works... until your shack is adopted by cats :D
    Then, you need switches.
    K0UO, N7EKU, KD2RDG and 3 others like this.
  7. KG7WGX
    I believe that if there is a remark made about cats and keys, it is obligatory to ask if one of the cats is named "Morse".
    N7EKU likes this.
  8. K1LKP
    I THINK HIS NAME IS "MEOW MORSE"..........
    PU2OZT and N7EKU like this.
  9. K2CAJ
    K2CAJ XML Subscriber QRZ Page
    Great idea. And with an external keyer like the UltraPicoKeyer, you can attach the Y cable and straight key (or bug) downstream, so that you don't even need to switch the keyer to hop between them.
    WA9UAA and KD2RDG like this.
  10. KC3RN
    KC3RN Ham Member QRZ Page
    I've done this with both my 450D and my 7300. It works great. It's actually a bit easier with the 450D, since the keyer can be turned on/off from the front panel. It's a menu item on the 7300, but not a big deal.
    KD2RDG likes this.
