SpiderDXman RH-DX1020 Cobweb Antenna
Discussion in 'Ham Made Gear' started by PY2QI, Jul 31, 2018.
  1. PY2QI
    PY2QI Ham Member QRZ Page
    1. [​IMG]
      ORDER NOW!!
      USd 259.00 FREE SHIPPING WORLDWIDE
      https://www.ebay.com/itm/153121503991
      Info: sales@radiohausamerica.com
      Restricted space spoiling your operating fun?
      RADIOHAUS RH-DX1020 Cobweb SpiderDXMan is the solution!!!
      20, 17, 15, 12, 10 Meters full half-wave Cobweb Antenna is perfect for restricted space or portable operation. Sky-gray fiberglass spreaders and nearly invisible wire elements (flat 9x9x1/2 feet square. 8 pounds), blend in with your surroundings while standing tough against nasty weather.
      •Omni-directional
      •Fiberglass supports
      •Perfect for restricted areas or portable operation
      •QRP to 300 Watts
      •No radials needed
      •Low SWR
      •Works at low heights
      •Fit on a mast or in a balcony!
      [​IMG][​IMG]
    KA8UGB and W1SRR like this.
  2. W1SRR
    W1SRR Ham Member QRZ Page
    what is the minimum height this should be mounted?
  3. PY2QI
    Hello Mike. I worked a lot of DX with this antenna, mounted on a Comet mast/tripod, only 3 meter (10 feet) over ground. You can see more information and download the manual at http://radiohausamerica.com/produto.php?prod=1709
    Feel free to contact me if you need further informatio.
    Erwin Hübsch Neto, PY2QI / KK4CGD
    W1SRR likes this.
  4. W1SRR
    Thanks Erwin, my only concern is the HOA but at 10 ft. I think it is low enough not to be on their radar, plus I can always say I use it to dry clothing, Hehe ;)
    Mike
  5. N0YPD
    N0YPD Premium Subscriber QRZ Page
    How would you rate these performance wise against a multi band vertical?
  6. K2LED
    K2LED XML Subscriber QRZ Page
    Any options for a larger BALUN?
