ad: hrd-2
Signalink USB in Virtualbox guest
Discussion in 'Computers, Hardware, and Operating Systems' started by W1LEM, Feb 3, 2017.
  1. W1LEM
    W1LEM XML Subscriber QRZ Page
    In order to use Andy's Ham v20 (linux distribution including most linux ham software), I downloaded Virtualbox and created a linux guest, into which I installed Andy's Ham.
    Everything is good except for one major issue: I am using a Signalink USB as a sound cars interface. On the host, I am able to select the sound card in WSJT-X and fldigi and operate. However, it appears that Virtualbox does not share multiple sound cards well. I have tried accessing the passed-through USB port, but the VM locks up.
    Google research reveals that this is a known problem.
    Has anyone figured out a workaround to enable access to a Signalink from a Virtualbox linux guest?
  2. W1LEM
    Here's the answer, in case anyone runs into the same problem. In virtualbox, settings/USB, with the Signalink connected there is an option to select "Burr-Brown from TI USB Audio Codec." I ticked that, but I could never get it to work--either no such option in the software or the vm would lock up. Subsequently, I installed andysham as host on another computer, plugged in the Signalink, and I got the burr-brown blah blah as an option in WSJT-X. So, I went back to the VM to see what I was doing wrong. The settings/USB dialog gave me 3 options to enable USB controller for 1.0. 2.0, or 3.0. I had ticked 2.0. DUH. I looked at the backe of the computer and sure enough I had plugged tbe Signalink into a 3.0 port. I changed the tick to 3.0 and it works.
