For Sale SGC- SG-211 AUTO PORTABLE TUNER
Discussion in 'Ham Radio Gear For Sale' started by KM4OP, Oct 30, 2018.
  1. KM4OP
    KM4OP Premium Subscriber QRZ Page
    Here is a nice condition SGC- Tuner model SG-211
    Mini smart tuner. Runs on Batteries. Will run up to 5 years on a set of AA batteries. This one has the lock/tune switch. It is NOT for high power, this is great for qrp or a bit more rf around 20watts continuous or 60watts Pep. Very light, will fit in a back pack nicely. could be Deployed at Feed point or at radio.
    I do not have the box . Operating instructions on the unit itself . Full manual available @ www.sgcworld.com
    $ 150 Shipped KM4OP@YAHOO.COM
    SG-211 Mini Smartunerâ„¢
    ZERO POWER CONSUMPTION
    Zero Problems.
    The SG-211 represents a revolution in automatic antenna tuning. There has never been a tuner so compact, flexible and easy to use. It will run for up to 5 years on a single set of AA batteries. No power connections, no control cables, nothing external is required. Just connect your antenna and RF from your transceiver to get on the air. The SG-211 makes operating fun!
    FLEXIBLE AND PORTABLE
    Compact and Durable.
    The SG-211 Mini Smartuner will work with any transceiver and most antennas, both balanced and unbalanced. It has a wide tuning range from .3 to 6000 Ohms and 256 memory bins, allowing accurate tuning and quick recall. Built into a rugged aluminum case and weighing only one pound, the SG-211 is the perfect companion for portable and QRP operation.
    Now supplied with a tune/lock switch. Look at the new front panel.
    TECHNICAL SPECIFICATIONS
    1.8 to 60 MHz
    1.5 to 60W (PEP/CW) and 20W (Continuous)
    45 to 55 ohms
    Typical: Less than 2:1
    Zero - Internal batteries
    Typical: Less than 4 seconds
    Typical: Less than 500 milliseconds
    256 non-volatile locations
    Minimum lengths: 8 feet(3.5 to 30 MHz)
    25 feet(1.8 to 30 MHz)
    Any position, ideal at antenna feed point
    -30 to +60 degrees C
    8.7L x 4.7W x 1.5H inches
    1 pound
    Irridited aluminum enclosure*
    SO-239 RF input connector
    Balanced and unbalanced studs with wing nuts
    No cables supplied
    Tune/lock switch built-in
    1 Red LED on front panel
    -Steady for 2 seconds for tuned
    -Blinking for 2 seconds for not tunable
    -Morse B for 10 seconds for low battery
    *Requires additional protection if installed outdoors.
    FOR MORE INFORMATION
    Compare Smartuner Specifications.
    Download a brochure or manual in pdf format.
    Read comments from other users.
    Read about real user installations.
    Look for technical notes on the SG-211.
    Review
  2. KM4OP
    TUNER HAS BEEN SOLD Thanks Please Close
  3. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
