SOLD Selling both AEA SWR-121-HF and AEA SWR-121-V/U analyzers
Discussion in 'Ham Radio Gear For Sale' started by WQ6N, Nov 13, 2017.
  1. WQ6N
    WQ6N XML Subscriber QRZ Page
    Selling both AEA SWR-121-HF and AEA SWR-121-V/U analyzers:
    AEA SWR-121-HF
    I purchased the AEA SWR-121-HF analyzer directly from AEA and am the original owner. I have maybe used it a dozen times since I have owned the unit which has been kept boxed during storage. The unit is in very good condition and shows no signs of wear other than the original screen protector that all of them have. 100% operational on both batteries and external supply. I use the AEA Software Director for plotting (not included). It is available online. The serial is #: 01200 which is one of the very late versions. I use rechargeable batteries which are not included. If you want to use an optional external power brick the connector takes a 2.1mm plug at 12vdc. Included is the original instruction manual. The manual is also available online if you need further specifications. I have included a couple of plot samples that I conducted on a OCF dipole.
    What It Does:
    The SWR-121 HF Antenna Analyst combines a microprocessor controlled frequency synthesizer with an accurate low-power SWR bridge to present a graphical display of SWR versus frequency. During normal operation, the Analyst continuously sweeps and plots the selected frequency range. You can define this "sweep" range using the Analyst’s keypad.
    Once installed on your PC, the optional SWR DIRECTOR software allows you to remotely control the Analyst as well as store and print plots.
    Features:
    • Graphical display of SWR versus frequency 1Mhz to 31.999Mhz
    • Digital readout of SWR
    • Digital readout of Return Loss
    • Auditory cues
    • Self-test and Calibration functions
    • Automatic plot scaling
    • Automatic centering
    • Automatic plot averaging
    • Automatic hold and Automatic off
    • Battery-powered and auto saver
    • RS-232 interface
    AEA SWR-121-V/U
    I am the second owner of the AEA SWR-121-VHF/UHF analyzer. Maybe used about 20 times since I have owned it. Both power sources are in order. Fully operational. Serial: #1076
    Features
    • Auditory cues
    • Battery-powered
    • RS-232 interface
    • Optional, PC-compatible SWR DIRECTOR software allows remote control and display as well as plot storage and printing (software and serial cable available from AEA)
    • Optional AC-1 Wall Cube (available from AEA)
    • Optional softcase with shoulder strap and swivel hook (available from AEA)
    Specifications
    • Frequency Range . . . . . . . 120-175 MHz, 200-225 MHz, 400-475 MHz
    • Default Frequency
    Step Size . . . . . . . . . . . . . 10 kHz
    • Manual Frequency
    Step Range . . . . . . . . . . . 10 kHz to 75 MHz
    • Display Resolution . . . . . 0*-1000 kHz per dot (*single frequency)
    • Display Width . . . . . . . . . 0-110 MHz (110 x resolution setting)
    • Impedance . . . . . . . . . . . 50 ohms
    • Output Power . . . . . . . . . Approx. 5 mW into 50 ohms
    • Harmonicsand Spurious . . . . . . . . . 30 dB below fundamental, typical
    • SWR Range . . . . . . . . . . 1:1 to 10:1
    • Return Loss Range . . . . . -0.3 dB to -50 dB
    • SWR Proportional Tone . . Approx. 200 Hz x SWR value
    • Accuracy . . . . . . . . . . . . . ±10% typical, when calibrated
    • Power Source . . . . . . . . . lnternal batteries or external 12 to 16 VDC
    • Battery Complement . . . . 8 AA Alkaline or Lithium
    • Battery Saver Mode . . . . . Entered after 4 minute idle
    • Display Update Time . . . Approx. 2 seconds per sweep
    • Serial Port . . . . . . . . . . . . 9600 baud
    • Size . . . . . . . . . . . . . . . . 4.3" W x 2.25" H x 8.5" L (including connector)
    • Weight . . . . . . . . . . . . . . 1 lb. 10 oz. (including batteries)
    I am asking $140 for the AEA-SWR-121-HF and $150 AEA-SWR-121-V/U and will ship via USPS flat Rate to lower 48. No Returns due to part swappers. Both units for $270 shipped to one destination. I will supply 1ea. serial plotting interface cable and 1ea. 12VDC power adapter that will service both units individually. I use the SWR director for both units in the DEMO mode. Paypal is preferred.
    NJ9P and KK6QMS like this.
  2. WQ6N
    The AEA 121-HF unit is sold pending funds
    The AEA 121-V/U is now $150 shipped to lower 40
  3. WQ6N
    AEA SWR-121-HF is confirmed Sold
  4. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
