Hello I recently acquired a second callsign, VE3GN, but haven’t posted it on QRZ because the page by the original owner of the call is still up. How can I post it without causing any confusion with anyone who might look up VE3GN? Regards, Robert Rodriguez VE3ROR,VE3GN
You will need to submit a trouble ticket at https://ssl.qrz.com/support to request that the callsign be reassigned to you as a "managed callsign." Be sure to include a copy of your amateur radio licenses showing you as the current holder of this callsign in order to aid with the processing. Once you receive notification that it has been completed, log out and then log back in and the VE3GN callsign record should be under your control and will be accessible and able to be edited at https://www.qrz.com/db/VE3GN. This is a routine request so should only take a bit of time, 24 hours at the most.
Robert, As a friendly reminder, you will need to submit a trouble ticket at https://ssl.qrz.com/support to request that the callsign be reassigned to you as a "managed callsign." Be sure to include a PDF or JPG copy of your amateur radio licenses showing you as the current holder of this callsign in order to aid with the processing. Once you receive notification that it has been completed, log out and then log back in and the VE3GN callsign record should be under your control and will be accessible and able to be edited at https://www.qrz.com/db/VE3GN. 73 de DW
