ad: HamInsurance-1
SB220 rebuilding help
Discussion in 'Homebrew and Kit Projects' started by W7NIK, Oct 31, 2008.
  1. W7NIK
    W7NIK Ham Member QRZ Page
    I have a sb 220 that I am rebuilding. Does anyone know how set up the tank circuit. I have the 80/20 coil modified, wire added on the bottom. The 10/15 has been cut and another coil added.
    The amp has been mod for the 17, 12meter bands. But the waffer swicth is bad. I am able to set up the input circuit with swr analizer. But how do I test the hight power side? Turn it on slowing add exciter power then see if it tune easly? IF it dosen't tune wrong band swicth on the High power side .
    Measure the coil and lenth of wire but where do I find the proper data.
    I can set up the tuned input fine but high power side I do not know.
    w7nik@arrl.net.
  2. KD8DEY
    KD8DEY Ham Member QRZ Page
    Fact Check Aisle 2
    If A single 3-500z had an output impedance of 500ohms so 2 in parallel would be 2500??
    17m 18.068-18.168 so the middle of the band would be 18.118
    12m 24.890-24.990 so the middle of the band would be 24.940
    According to the W6SAI Book (great book)
    for 18.1mhz tuning cap should be 32pf, inductance 2.6uh, load cap 147pf.
    for 24.9mhz tuning cap should be 23pf, inductance 1.9uh, load cap 107pf.
    Its too early to be trying to think, just got the grandson off to school, no coffee yet. and I'm a no nothing general lite. Soooo
    WE NEED A FACT CHECK ON AISLE 2
    Aisle 2 fact check please!!:D
  3. KD8DEY
  4. W7NIK
    sb 220
    EXCELLENT thank you , How do i verifiy if the coil is the right coil. I have modified original coils that were cut and added too original coils. This was a SK amp wih out docments. I would like to restore it one day . The tuned input no problem.
  5. W7NIK
  6. KD8DEY
    Ocean State
    Ocean State electronice sells an inductance tester that you could use to verify/adjust the tap point on what you have.
  7. KL7AJ
    KL7AJ Ham Member QRZ Page
    Do you have a grid dip oscillator?
