SB-221 Heathkit AMP Bias Mod T/R Relay 100k Question
Discussion in 'Amateur Radio Amplifiers' started by N0OHL, Dec 4, 2019.
  1. N0OHL
    N0OHL Ham Member QRZ Page
    I have been going thru a working SB-221 and am getting ready to what is called the Bias Mod. I would like to thank W1QJ for his great description of the Mod details.
    https://forums.qrz.com/index.php?th...modification-rewire-yes-or-no-and-why.593843/
    However, checking the details of how my SB221 was built, I found something interesting. The resister to be moved to the next contact in my AMP is 54ohms -- and everything I can find says it should be 100k. However, the relay/amp seems to be working all right.
    However, I am thinking I should replace th 54ohm Resister with a 100k one when I move the wires around with W1QJ directions.
    Pictures below of how it looks now ( before Mod ) ( the extra white wire is to power a Soft-Key -and will be left)
  2. N0OHL
  3. WB2WIK
    You're reading the color code from the wrong end of the resistor.
    That's 100K: Top stripe brown (1), next black (0), next yellow (4 zeros) = 100,000. The green band is the tolerance: Green = 5%.
    K7TRF likes this.
  4. K7TRF
    Yup, that's a 100k resistor...
  5. N0OHL
    Wow....sure glad I put a picture here
  6. K7TRF
    Well, there's no harm in replacing the 100k resistor with a.... 100k resistor other than the cost of that resistor :)
  7. AI3V
    AI3V Ham Member QRZ Page
    Fixed it for you :D
    Rege
    KS4W likes this.
  8. W2VW
    W2VW XML Subscriber QRZ Page
    I like the last picture. It looks like the components are covered with fuzz from a capacitor explosion.
    KD2ACO likes this.
