ad: HamInsurance-1
Samsung Gas Stove.....
Discussion in 'General Technical Questions and Answers' started by KN4OWI, Dec 15, 2019.
Tags:
ad: QSOToday-1
  1. KN4OWI
    KN4OWI Platinum Subscriber Platinum Subscriber QRZ Page
    I recently purchased a Samsung Gas stove. It has electronics that control the oven part. Just this weekend it started to try and program its own temp and cook time. Wife was not happy! Then I realized it was me on my radio causing it to program. I am running an Icom IC-761 at 100 watts and an MFJ-2010 wire antenna. I plan on running a separate ground wire to the stove to start with but any other suggestions?
  2. WE4B
    WE4B Ham Member QRZ Page
    Get another brand stove that is able to reject the licensed radio signals from your radio or don't use the radio while cooking.
    KY4GD, PU2OZT and K3XR like this.
  3. KK5JY
    KK5JY Ham Member QRZ Page
    I would choke the power cable first, if possible. Wrap a few turns on a bead and see if that solves the issue.
    I'm not sure I would be comfortable playing games with how a combustion stove was electrically grounded.
  4. WR2E
    WR2E Ham Member QRZ Page
    I would contact Samsung.
    It's an obvious safety hazard, they'll listen to that.
    PU2OZT, KS2G, W1TRY and 3 others like this.
  5. K5ABB
    K5ABB XML Subscriber QRZ Page
    I'd second that, let THEM sort it out
    PU2OZT, N2EY and KN6SD like this.
  6. WZ7U
    WZ7U Ham Member QRZ Page
    Unless gas stoves are your forte, I agree with the previous posters wholeheartedly. Not worth the chance.
    PU2OZT likes this.
  7. KA0HCP
    OCFD, 40/20/10/6M, DIPOLE, 300W (coax fed).
    Well, OCFD's are prone to Common Mode current on the coax shield as well as creating RFI.
    Standard stuff....
    -Reduce power to level that doesn't cause problems
    -Change bands
    -Reorient antenna
    -Move ant. further away, elevate ant.
    -Add 1:1 Unun/Isolators at Feedpoint and at shack entrance.
    -Add a grounding point/surge suppressor at shack entrancej
    -Change antenna to a balanced design i.e. traditional center fed dipole.
    PU2OZT, KC3PBI, NN4RH and 1 other person like this.
  8. WZ7U
    I missed the part about an OCFD, I'm not up on MFJ part numbers.
    So, yeah. I'm not saying it's the OCFD, but it's the OCFD.
    KY4GD, KA0HCP, K4AGO and 2 others like this.
  9. NJ6Q
    NJ6Q XML Subscriber QRZ Page
    KN4OWI,
    Did you ever resolve this problem with your oven? I am having the same issue with my relatively new Samsung Oven (Model #NX58H5600SS/AA). When I operate on 40m it will turn the oven on. I am not using a OCFD, but rather an elevated vertical with tuned radials on the roof. My plan is to use ferrite on the AC cord of the oven. I am concerned that a lack of internal shielding may be the cause and ferrite may not be the solution based on a write up by KF4G, although I was planning on a toroid FT240-43 rather than using clamp on chokes): http://kf3g25cw.altervista.org/Links/Samsung_NX58H5650W/Samsung_NX58H5650W.html
    I can't move my antenna and I have a 1:1 unun at the feedpoint and at the radio.
    Thanks for info you can share.
    73, Jeremy, NJ6Q
  10. WF7A
    WF7A Subscriber QRZ Page
    Get rid of wife. Problem solved.
    PU2OZT, KQ9J, VU3DRU and 1 other person like this.
