Sailing Boat Antenna Help
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by 2E1HPS, Apr 21, 2020.
Tags:
  1. 2E1HPS
    2E1HPS Ham Member QRZ Page
    Love the video thanks.
  2. KL7AJ
    KL7AJ Ham Member QRZ Page
    Yep, that's exactly what I do. If you have a multiposition switch, you can also switch in different fixed capacitors.
    I built a FET dip oscillator for 630 meters....I plan on getting it published in either CQ or QEX pretty soon. Most of the commercial grid dip oscillators don't go down below 80 meters.
    Also, check out the RSGB book, LF Today. I will be a contributing author for the next revision.
    73 es happy sailing!
    AK5B likes this.
  3. K2EDM
    K2EDM Ham Member QRZ Page
    best I have ever done is pulling a dipole [end of it] up a halyard with the other end to the stern ass far away from the backstay as possible.....worked OK on 20..non-resonant antennas work equally poorly at whatever freq they are nonresonant at.......Pearson ariel [1990] , I had a 2 meter gnd plane on the top of the mast..never a ship/shore radio though, cause the coast guard seys that if you have one, you must have it on... ed k2lck
  4. KL7AJ
    I have no problem with mandatory radio watch. Plenty of good tradition for that!
  5. KL7AJ
    I'm even thinking of getting an official radio watch clock for the shack. They do look cool
    AK5B likes this.
  6. 2E1HPS
    Pearson ariels a nice boat a bit similar to the contests 26. Seems to be a good idea to use the mast to support a vertical wire antenna interesting about the dipole. Ground plane antenna is interesting also. I had a company try selling me a discone antenna for the top of the mast to.
    Any thoughts?
    A radio watch clock for the shack is a great idea.
  7. 2E1HPS
    Also how would you rate:
    active mini whip antennas
    And
    ferrite loop antenna
    For use at receiving at 490kHz
    2E0CIT likes this.
  8. K2EDM
    discone isn't a bad antenna at all,vert pol & great bandwidth,just difficult to consteruct......radio watch w/o a battery equalys a dead radio,....just had outboard on the ariel..
  9. K2EDM
    ferlower freq, might try an inverted V with the center pulled up by halyard and the rest going to the front and back of the boat.. as I said before, I believe in resonant antenanas...
  10. 2E0CIT
    2E0CIT Ham Member QRZ Page
    Hi James!
    It must be GREAT to combine sailing and hamming! (And excellent wx for sailing now from Ramsgate, -my favourite seaside town!)
    I have various antennas including homebrew Miniwhips for reception but also a commercially made 'Scanmaster' active antenna
    It's excellent for the lower bands of HF and at MW and VLF. Noprobs receiving WEFAX, NAVTEX, etc.
    It is sold as a 'plug & play' but I found it works much better if you make two additions:
    -put a toroid current choke on it where the coax enters the antenna, -it chokes off rfi picked up on the feedline shield.
    -ground it. I wired a ground wire from its circuit board to an earth stake. I gather that others earth the coax shield as the coax reaches the ground .
    You have the best 'earth' of all under your boat!
    73 Hope to QSO! Jeff
    https://www.ebay.co.uk/itm/Scanmast...900438?hash=item2a57564e96:g:rT8AAOSwYmZXKepl
