Sailboat HF Antenna
Discussion in 'Mobile Radio' started by N2DGM, Feb 12, 2020.
ad: OK1UUad-1
  1. N2DGM
    N2DGM Ham Member QRZ Page
    Has anyone had experience using a wire beside the back-stay Hunter 34.4 1982 , don't really want to mess with the back-stay to be used as an antenna ..?
  2. W5UAA
    W5UAA Ham Member QRZ Page
    In both my boats in the past (a 34' wooden sloop on Oahu, and a Catalina 27 in Florida), I thought about a variety of methods to use that nice tall mast as an HF antenna or antenna support. In both instances, I finally came to the conclusion these two hobbies just don't belong together. When the winds are fair and the sea is calm, I'd rather be at the tiller or wheel saying things like, "Helm a-lee!" and watching the dolphins ride my bow wake.
    But if I were to try to set up to operate while on a hook or in my slip, it would have always ended up just being a long wire and a tuner. An insulated wire hoisted up the main in some form or fashion is about as good as I can imagine it getting.
  3. N2DGM
    Thank You for your Reply,,, Safe harbor or at Anchor/night ---- when to operate ----Good information---!!
  4. K0UO
    Search the other post and threads on QRZ.
    There's quite a bit of information over the years.
    There are thousands upon thousands of marine HF Radio setups on sailboats, and many of those are also used for ham radio.
  5. N2DGM
    Thank You !! will check out HF Radio setups on sailboats for ham radio...
  6. KO4MI
    KO4MI Ham Member QRZ Page
    Specific to your question, that configuration is called an 'alternate backstay antenna.' Lots of good ways to do it. The big deal is enough elasticity in the mounts to keep it from taking a load. Bungee at the top does nicely and provides an insulator from the mast.
    From where you are you should be able to reach the Waterway Radio Net, 7268 kHz LSB 0745 US ET daily.
