RV Antenna
Discussion in 'On the Road' started by W4BLU, Jul 10, 2019 at 6:05 PM.
  1. W4BLU
    W4BLU Ham Member QRZ Page
    I've recently installed a CB radio in my RV to monitor road issues while traveling. The antenna was installed by the RV manufacturer (Tiffin) on a fiberglass roof. I'm unable to get below 3 when trying to reduce reflective power by using the stinger with the antenna. Any suggestions on how to reduce the SWR?
  2. KD0CAC
    KD0CAC Ham Member QRZ Page
    What kind of antenna - no info , no answers ?
  3. W4BLU
    Wish I knew what kind of antenna it is. No markings that I could find. Does have a spring base and I've extended the stinger out as far as possible.
  4. KD0CAC
    Dimensions , pictures ?
    Some antennas require radials , maybe the stinger is cut too short .
    The spring base , is most likely a added option & could be interfering , try without .
    If you know nothing about it , then you may have ended up with a damaged antenna ?
